| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
07-21-2008, 05:26 PM
ont
Cobra Make, Engine: D&D Cobra,302 stock for now,IRS
clutch slave cylinder
Do you guys have a picture of your slave clutch cylinder preferably on a t-5 with the stock bell housing,i need some ideas 'cause i need to buy one but they don't sell the brackets,thanks
07-21-2008, 06:22 PM
PA
Cobra Make, Engine: CSX2498 has been in our family garage since '68....Scratch built aluminum bodied 427SC Cobra, 427FE, CSX3000 chassis specs, 95% finished, only needs paint.
slave cyl. bracket
Hello, here is a photo of a slave cyl. bracket I made for a 289 Cobra with a original 5 bolt COBRA bell housing. It is a piece of 1/4" x 1.5" angle with a slight curve to match the arc of the bell and a mounting point for the CNC slave cyl. It can not be too much different from what you need.
regards, karl
http://www.clubcobra.com/photopost/d...s/HPIM0850.JPG
07-21-2008, 07:05 PM
Ca
Be aware of the differences between the ones that "Push" or "Pull" type cylinder. This is a clone of the OEM type that used a "push" type, it uses an OEM slave with an aluminum instead of fabricated steel mounting bracket.
[IMG]  [/IMG]
Rick
07-21-2008, 07:25 PM
OK
Cobra Make, Engine: RUCC, 289 c.i. with a T-5 "Living the Cobra Experience"
I'm using a push type Tilton slave cylinder with mine on a T-5 with a stock bellhousing.
You can buy the bracket, I got it from DazeCars, you can google them for their web address. The bracket fits perfectly.
I attached a picture below, click on it to get a better look.
PM me if you need any more info.
Randy
Juggernaut
07-21-2008, 08:05 PM
Club Cobra Member
OH
Cobra Make, Engine: A&C 427S/C, 351W, T5
Here's what I used, got the kit from JMC Motorsports 619-401-6900
www.autoworksracing.com.
Worked great no problems.
Jim
07-22-2008, 06:21 AM
OK
Jim
That's exactly what I'm using & it does work great.
Randy
Juggernaut
07-22-2008, 08:50 AM
ont
slave cylinder
Thanks guys it's exactly what i need,i will contact them to see how much they want and if they can ship in canada,cheers
michel
Jim
07-22-2008, 10:04 AM
OK
You're welcome Michel.
I asked that same question a while back & I'm just passing along the info I received from the fine folks on this forum!
Juggernaut
07-22-2008, 05:11 PM
ont
Thanks Randy,i contacted Donald at D&D Cobra my manufacturer and he has the kits and he will give me one.
07-22-2008, 09:11 PM
speedway motors unit. I used a angle bracket to the motor mount.
cheers
rdc
07-28-2008, 02:58 AM
ont
Thanks guys,what i was looking for is like the picture JIM posted,a push type style,cheers.
Michel
