| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
08-20-2008, 03:10 PM
CA
Cobra Make, Engine: Still Working on This
Quick Release Steering Wheel Hubs
Did a bit of research on this in old threads.
Based on what I found, appears to be one source of these for Cobras, Sterling Replicars Pinless Quick Release Steering Wheel Hub? Is this correct?
Also, has anybody successfully registered a street car here in the Golden State with one of these?
Think I need to shed a few pounds....
As always, appreciate member input.
Bob
08-20-2008, 03:43 PM
Cobra Make, Engine: original a/c. shell valley 427. daytona coupe
Bob we build our own, In a mannor that is hard to tell that it is a quick release ,but a lot will depend on what column you our using and what directional assemble you have. We use a custom column with the original vw type 1 directional and hide the release button in the hub behind the wheel. If you contact me I could maybe send you photos to give you an idea.
08-20-2008, 04:20 PM
Beam Me Up Scottie
MA
Need to go on a diet? I'm on one now.
Here is a thread about what I did to make my SPF more comfortable.
http://clubcobra.com/forums/showthre...919#post783919
Warren
08-20-2008, 06:30 PM
WV
Cobra Make, Engine: SPF 2682, Roush 427
There is a picture of my quick release in my gallery. The NRG unit requires a little
modification to make it work.
08-21-2008, 09:36 AM
wa
Are we related?
08-21-2008, 10:11 AM
CA
Cobra Make, Engine: West Coast Cobra w/ Centrifugally Blown Big Block, Pickles, Onions, on a Sesame Seed Bun.
Sweet Mfg.
I used a standard stock car type quick release by Sweet Mfg.
This is one of those things where function is as important as fit. I could have bought a bolt-on unit, but couldn't find one that had a tight spline fit (returned two of them).
The Sweet unit was just that...sweet...but had no bolt-on adapter so I turned a sleeve on the lathe, set the adapter in place, and welded it on permanently.
No slop at all...and very very nice function.
08-21-2008, 10:49 AM
Cobra Make, Engine: spf 2112 *427 stroker windsor
CSCHWER; What model #ngr unit did you buy for you superformance and what mods did you make to allow it to fit. Looks like you made it fit into the existing spf outer housing. Looks like a clean retrofit. Two thumbs up!
PS; Does the wheel stick out further than before the quick release.
Regards Carmine
08-21-2008, 12:37 PM
Ga.
Check out, Coleman Mfg. and stock car products........
Perry
08-22-2008, 07:19 PM
CA
Thanks to all for your replies.
I take it then that none of you had any problems registering the car in your respective states with the quick release wheel?
Bob
08-22-2008, 08:43 PM
CA
Ca..
In CA there are only a few hurdles to register a car...
Brake and Light Inspection (sometimes, if the DMV asks for it). They don't check for steering wheels, or quick releases.
CHP Inspection. They check the VIN and MSO and assign one if it doesn't have one. They didn't look at anything else and never even looked at the engine bay...mine was on a trailer at the time with the hood off and no seats or wheel at all. They didn't care.
BAR Inspection. All they care about is the tailpipe and whether or not it runs. They don't care about he wheel.
DMV. They never see the car.
Therefore...no issue. Are they illegal? Don't know, but the last time I got pulled over, I pulled the wheel off, set it in the passengers seat, and stepped out. The only thing the cop said was "wow, cool."
08-23-2008, 04:57 AM
Ga.
If you don't tell them about the quick disconnect, there's nothing to sweat!.
Perry
08-23-2008, 07:24 AM
Charter Club Cobra Member
OR
Cobra Make, Engine: My Shell Valley Coupe is here! Now the building begins....
Take a look at these, I have one on my coupe and it is excellent.
http://www.jblmotor.com/ProdS/Steering.htm
Scott S
Working as hard as I can every day to double my carbon footprint.
