| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
01-07-2009, 11:53 AM
UK
6 pin knock-ons - advice needed
Hi guys, first new thread posted here, although been lurking on and off for a while.
About to start a new car build and bitten by the authenticity bug.
I'm looking for some advice on knock-ons which are far more common your side of the lake than here in the UK.
Can anyone tell me whether its possible to fit a 6 pin knock-on wheel onto a jaguar (5 stud) hub (front and rear, same pcd though).
I found a thread that looked like ERA did something, but looks like a bespoke or replacement hub assembly (big $$$?), maybe only for the rears. Unfortunately i didnt understand everything that was written there by someone who seemed to have solved the problem with FIA wheels.
Hope you can help.
Kevin
01-07-2009, 12:07 PM
Kevin,
You can't do 6 pin wheels on a Jag 5 pin hub. You have two choices - replace the hubs with 6 pin hubs (Justcobras.com, about $850 for four) or use the very popular 5 pin wheels with adapters. Vintage, Trigo, PS Engineering, all of them sell tons of these, and from the outside they all look the same. Good luck, and welcome to the madness!
Doug
01-08-2009, 10:07 AM
UT
Cobra Make, Engine: FFR 3850, 95 Cobra 5.0 EFI, IRS, Pin Drive 15" real Magnesium Halibrands & Vintage Wheels, Billboards & Mickey Thompson S/T tires, Blue/Wht Stripes, Hoops, CSX Dash, Konis, VPMs, Torsen
6 pin
Hope you can help.
Kevin
Kevin,
Welcome to Club Cobra!
As you know, Simon Finlay makes a replacement Jag hub for the pin drive rims. The ones he has made so far are 5 pin to fit the common wheel. But, his design seems like he could make 6 pin, 4 1/4" bolt diameter (or as needed) just as easily. The Simon hub is on the left; notice how it is shorther than the adapter system on the right, thus "narrowing" the front track an inch or more per side. (Needed for Jag-based kits.)
Then you could get 6-pin Vintage Wheels for the "all original" style setup.
Just an idea,
01-08-2009, 11:15 AM
UK
Thanks guys.
Doug, reason is I am thinking of using 16" knock-ons (have my eye on a second hand autocraft set). 16" tyres are far more plentiful in the UK than 15". but 16" halibrand knock-ons only come with 6-pin drive as far as I can find. Back to the drawing board.
I was thinking about that idea Larry, but i would still have a problem as simon's adaptors are only for the front - am I wrong?
would 15" rear and 16" front look stupid?  :
cheers,
Kevin
01-08-2009, 11:38 AM
UT
Thanks guys.
cheers,
Kevin
Kevin,
Simon can do both front and rear hubs for the Jag setup. Or get Simon fronts and www.justcobras.com rear. That way you get the narrowed front track you will need; 6-pin, no adapters. Image of justcobras rear Jag hub:
Then you can order Vintage Wheels w 15" tyres mounted and balanced, so 15" tyres should not be an issue. They seem to last forever. For example, I have a set of Goodyear Eagle GTII w 6 seasons, 21,000 miles, about 50% rubber still left.
16" on one end and 15" on the other would not be the "original look". Some compromises to originality are generally made by us all. After a while, it's okay. Vintage has sharp 17" pin-drive rims, if that helps you.
Keep after it, Kevin...you'll find what you want eventually.
Regards,
01-09-2009, 07:37 PM
Larry, How does one contact Simon? Do you have phone, email or website contact info?
01-09-2009, 09:39 PM
FL
Cobra Make, Engine: Building 289 Lemans / FFR mkIV chassis w/ Bruce Chervenak
woah daddy that's a low sidepipe.
01-10-2009, 10:40 AM
UT
Simon
See Simon Finlay web info . You may have to PM him.
It is his personal business, not a major company. He is in the UK.
| Thread Tools |
| Display Modes |
Hybrid Mode
