01-19-2009, 02:14 PM
SeaFoam
I'd like to hear any members experiences pro/con with the use of this old time product. Particularly, what purposes it's used for and the results achieved.
Not looking for magic in a bottle.
Chas.
01-19-2009, 02:53 PM
Cobra Make, Engine: 1969 Mustang Fastback Pro-Street, constantly changing ongoing project!
But if anybody knows of any magic in a bottle- I would be interested in that!!
Mick
(Of The Troops & For The Troops)
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body; but rather a skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, WHAT A RIDE!"
01-19-2009, 02:58 PM
hello this Is Bryan from B&B manufacturing, we just built a 34 3 window coupe for the speed channel and Seafoam was one of the sponser, we put the engine adative in a 350 chevy for this episode of the show and I thought the stuff was amazing, I would recommend the product highly:
01-19-2009, 03:37 PM
SC
Cobra Make, Engine: Classic Roadsters '66 427 Replica-SOLD
I have used it in my 04 Marauder and the Cobra......can't tell anything about use in the oil but I did use it in my Marauder's intake and it seemed to smooth the idle up quite a bit!!
I metered it in through the PCV vacuum fitting...shut the engine off and let it sit about 30 minutes......started it and smoked up the whole neighborhood!!  Ugly stuff actually came out of the exhaust too....supposedly cuts carbon off pistons, valves and cylinder heads??
I feel like it improved performance some but with the supercharger it's really hard to tell??
Coosawjack
01-19-2009, 05:35 PM
Would you users say it's like Marvel Mystery? Sort of "upper engine lube"?
Thanks for input.
Chas.
01-19-2009, 06:53 PM
MA
Cobra Make, Engine: ERA FIA #2039
Sea Foam
One Place Where I Find This Stuff Works Is In The Gas Tank Of My C5 Corvette. For Some Reason My Gas Guage Would Quit When I Got To About 1/2 Tank. I Put Some Sea Foam In And It Cured The Problem.
01-19-2009, 08:05 PM
AL
I bought a ruff 79 Ford truck with a 302 C-4. The motor would die while driving down the hiway. Hard to crank sometimes. Coach Mike put some Sea Foam in the fuel line and the rest in the gas tank. Problems cured. I had bought a rebuilt kit for the carb but after a couple of months I took it back.
Riding mower was running ruff and would die on me. Sea Foam cured the problem. I had never heard of the stuff before but now anytime I have a motor/fuel problem, I try the Sea Foam cure first.
Great product
For me it's "magic in a bottle"
Dwight
01-19-2009, 08:47 PM
tx
Maybe works OK in gas engines, but I've tried it in my diesel engine twice, and twice it clogged up the fuel filter. I think the best proven product like Seafoam is RXP.
" It ain't no big deal"
01-19-2009, 08:50 PM
Ont
Cobra Make, Engine: Classic Roadster with 427 center oiler
I use it in everything to decarbon the cylinders. When I put the cobra away for the winter, I pour SeaFoam down the carb until the motor stalls (engine smokes like a bugger). In the spring when I start it, it will smoke for a few minutes until it warms up. I haven't pulled a head off to see if it removes carbon build up or not but the plugs seem clean.
I ran some of it through my 2 stroke weed wacker (it was running rough). So much carbon came out that it plugged up the spark arrester. After I cleaned the spark arrester out, the weed wacker ran like new.
I also use Seafoam in my 2 stroke 250hp Yamaha outboard motor. I add it to the gas tank. Keeps the spark plugs running clean.
life is short: eat dessert first !
01-19-2009, 09:31 PM
I used it in a old 350 injected chevy motor to clean the injectors and smooth out the idle. I have to say it worked as advertised. Mileage went up, power increased, the idle smoothed out.. I won't call it magic, but it does what it says it does.
Dan in Arizona
CCX3209
01-20-2009, 12:59 AM
Cobra Make, Engine: VSE alum. frame, FFR carbonfiber body (under construction)
I used it and it cleared-up my complextion, freshened my breath and added 40 points to my I.Q.! (Sorry, I just couldn't resist....all though I didn't really fight it all that hard.)
01-20-2009, 06:42 AM
Thanks for the replies-I learned a lot more from them.
Chas.
01-20-2009, 07:00 AM
Now I'm curious, I'll have to check out this stuff called Sea Foam..maybe it will help my jeep?
Bill
01-20-2009, 07:21 AM
Ga.
It contains Naphtha and pale oil, I'm guessing it's mostly the Naphtha which is a paint thinner?. Just another petroleum base product.
Perry
01-20-2009, 11:41 AM
Banned
How can that be good for your engine bearings? If you are "washing" (burning?) the carbon off the piston tops and cylinder valves, then some of that has to be working its way onto the cylinder walls and/or oiling system? Or is the dilution factor just not enough to worry about (i.e. run the Seafoam and then immediately change the oil)?
-Dean
01-20-2009, 02:50 PM
I asked a chemist buddy of mine (works for EXXON) about naphtha, he said it is mostly used in paint thinners and Coleman fuel.....a petroleum distilate....very high octane rating, depending on where you find it, it could be from about 110 to 125.........
When I drag raced my 65 fastback (351-W), I would drive to Auto Zone, buy a gallon of virgin lacquer thinner (about 4 bucks then), 99% naphtha,borrow a funnel, pour it in the gas tank and go across the street and fill it up with 93 octane premium and go to the track, done it numerous times over the years, maybe as many as 20 or more, same motor, same everything still in the car today.......runs great,never had any problems....
I would think the amount of Sea Foam used in a tank of fuel would help, but not be enough to hurt bearing or cause any other problems.....
My brother-in-law uses it in his two boats (outboard motors) and swears by it and so does the local boat dealer........
DAVID GAGNARD
01-20-2009, 04:01 PM
This could be magic in a bottle...
Chas.
01-20-2009, 06:38 PM
I love it!! It caused me to have an erection lasting longer than 4 hours!
MadMiles442
01-20-2009, 07:41 PM
Cobra Make, Engine: Unique 289 FIA HiPo 289 with Shelby dual quad intake
your suppost to see your doctor when that happens
01-21-2009, 01:22 PM
Ont
I found a data safety sheet on the internet about SeaFoam. The contents were listed as:
Pale oil - 40-60%
Naptha - 25-35%
Isopropol Alcohol - 10-20%
It does remove carbon build up though!
Paul
