Old 05-25-2009, 02:33 PM
Jac Mac,
You have a PM.
Chas.
Old 05-28-2009, 06:57 PM
Cobra Make, Engine: Superformance #2689 Roush 427R TKO 600
Does your oil pressure spike, peg your gage when you start it up cold? We had a car doing that and the oil pump relief was turned all the way in and he blew two coolers. Changed pump and new cooler problem fixed.
Old 05-28-2009, 09:02 PM
CHANMADD's Avatar
Hello!! Water boils at 100 c or 212 F at sea level, that's the temp that the water "boils off at! Straight science. The pressure will always be a little higher at cooler temps,so one should be aware that you should not "jazz" the throttle when the motor is cold.
I have had a few of these...replaced with a new one every time I overhauled the engine.
http://store.summitracing.com/partde...5&autoview=sku
The last time I installed with hose and no clamps and absolutely no leaks!!! Very clean install!!
John
Old 05-29-2009, 07:37 AM
Cobra Make, Engine: SPF #298 427 FI
John
Oil does not need to reach 212 F to drive away the water. If that were the case no vehicle I every owned would last more than 6 months. I have not found anything specific to cars but written anywhere but anything do with aircraft states the minimum is 155 to 165 F. I think it should be a little higher for cars but it does not have to be over 212 degrees.
Old 05-29-2009, 07:45 AM
I agree if water had to get to 212 degrees to evaporate, your driveway would never dry after a rain, etc.
Display Modes
