Old 05-25-2009, 09:35 PM
Cobra Make, Engine: Contemporary, 427 SO
Unhappy Clutch Problem
I have an early Contemporary Cobra with an external slave cylinder. The slave is engaging when it is cold. It does not move very far, but appears to be operating in a normal fashion. I take the car out and the clutch will engage, but once it is close to operating temp the clutch fails to engage and you can not get the car to shift. My guess is that I may have water or air in the system. I haven't changed the clutch fluid for at least five years. I recently changed the adjustment on the clutch so that it would engage up high and thereby extended the length of the throw on the clutch pedal. Any ideas or suggestions would be appreciated.
Thanks,
Len
Old 05-26-2009, 03:14 AM
Default Start with a flushing of the fluid
leonardU Leo You can try a fluid change first to see if this will help. Stay with DOT 3. If the pedal doesn't improve you may have to get a new slave or master cylinder to fix the problem. Are there any leaks you can see or moisture around either the master or slave? if yes the internals seals are breaking down. The other thing that it could be is the clutch fork could be bending or be cracked around the pivot in the bell housing. Try the fluid change first and see how the clutch pedal feels. You may also want to do the same for the brake system too. Rick L.
Display Modes
