| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
1Likes
06-06-2009, 01:13 PM
Ut
Neutral
New! Kirkham 427 FE Billet Flywheel Twin Clutch
Fellow Car Nuts:
As the automotive industry stinks right now, and we probably won't get a bail out, we decided to go into the dairy industry and make Swiss Cheese
In the never ending quest to remove weight from the car, Sandwich and Thomas got together yesterday and created a little more eye candy for all of us. This is our new Billet Aluminum 427 FE flywheel and pressure plate assembly. The twin-disk clutch unit is from McLeod. They didn't have an FE flywheel for the set up, so we figured we'd make one.
Removing mass from around the outside of the flywheel is more important the mass from the inside as the outside mass has a greater moment of inertia. Anyone who has driven an FE with a steel flywheel knows how nice it is to remove some of that weight. Your motor spins up MUCH faster, making it so much easier to shift gears quickly. Frankly, I can't stand to drive a car with a steel flywheel--they take way too long to rev up so you are always waiting to shift gears.
06-06-2009, 01:15 PM
Ut
Neutral
Since it is easier to put our cars on Weight Watchers than ourselves...
We figured while we were at it, we'd remove a little of the "extra" aluminum.
06-06-2009, 01:16 PM
Ut
This set up is for a Tremec TKO 600
06-06-2009, 01:18 PM
Ut
Here you can see the twin clutch disks.
06-06-2009, 01:23 PM
Ut
Now for the good stuff..
This entire set up 23.76 pounds!
06-06-2009, 01:25 PM
Ut
This is the original type set up with a steel flywheel and normal pressure plate. It weighs 65.85 pounds for a 42.09 pound savings! Our new set up is about 1/3 the weight. No wonder the original cars reved up so slowly.
08-05-2011, 03:45 PM
Ca
Cobra Make, Engine: KMP 201 427 SO Tunnelport
Hey, That looks like the setup McCloud built for me years ago, BUT mine has the 3/8 big input toploader spline.
08-05-2011, 06:17 PM
KY
Yes, McLeod offers the "Street Twin" clutch kit in a 1-3/8" size for Toploaders.
06-06-2009, 03:27 PM
CA
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
Got one for a small block?
06-06-2009, 05:56 PM
I was thinking the same thing!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
David
DAVID GAGNARD
06-06-2009, 06:48 PM
LA
Cobra Make, Engine: CSX4083, NOS 427 SOHC, serial number 589. Dyno'd in 1967 at 629HP with single 4v 560 Holley. Now with 4 Webers.
Horsepower rating?
06-06-2009, 07:15 PM
CA
David,
Very nice work as usual!
Did my eyes deceive me or did I see sintered iron discs in that uber light assembly? Two more questions; which McLeod pressure plate is that and how much plate load does it provide.
Thanks - especially for the inspiration, again and always.
Ed
06-06-2009, 10:40 PM
Ut
Originally Posted by eschaider
David,
Ed
Thanks for the kind words. Yes, they are sintered iron. I can't wait to try them.
I am not sure which plate it is. I posted those just before I had to run out to Congressman Chaffetz's fundraiser. I just got back; I'll find out and post it Monday.
David
06-06-2009, 10:02 PM
Ut
Originally Posted by Full Throttle Al
Horsepower rating?
I don't remember right now. I'll have to ask McLeod or look it up. It is a standard unit they use. I can't wait to give it test drive.
David
06-08-2009, 03:39 AM
KY
David
There are two twin disc McLeods available. One is the RST, the other is the RXT. The former is rated for 800hp, with two organic discs, the latter is rated for 1000 with two dual friction discs.
They will bolt up to any FE flywheel, with any pressure plate pattern. I can get them for a TKO, Toploader, Jerico, small block, big block, whatever you want to run.
If David is interested in doing a package deal, I can provide the clutch components if he wants to do the flywheel.
06-06-2009, 09:57 PM
Ut
We were talking about that today. I am sure we will be coming up with one soon. We were actually thinking about making a billet bell housing and seeing if we could make the ring gear much smaller to make the whole package smaller. We would then have to put the starter in from the rear.
David
06-06-2009, 04:07 PM
CA
Cobra Make, Engine: KMP241 427 S/C 482 Shelby
David,,,,,,,Looks great, but I need help with my hood scoop........Ron
RON N BKFLD
06-06-2009, 09:59 PM
Ut
I'm going to have to borrow one from another car!
David
06-06-2009, 04:35 PM
CA
David,
I was thinking it might look like this:
It would save weight and ...well I don't know what else it would do once it was installed, cus no one would see it. But if you think of it like a girlfriend, you know what she has under her clothes and that counts for something
Rob
06-06-2009, 10:01 PM
Ut
David,
Rob
Rob,
Pretty sweet flywheel!
David
| Thread Tools |
| Display Modes |
Hybrid Mode
