Go Back   Club Cobra > General Discussion > All Racing Talk
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 08-13-2006, 02:03 PM
Default AutoCross Help
I have A johnexx MotorSports Cobra,with a All aluminum 427.
Suspension:
The rear is a 4 link adjustable with panhard bar and ford 9".
The front suspension is Mustang II with adjustable coilovers.
So how do I set up the suspension?
Guy
Old 08-13-2006, 09:31 PM
LMH's Avatar
LMH LMH is offline
I'm not joking when I say books are written about suspension set ups for all types of racing. Might look at the rules and classification (like the SCCA) for your car first. That may tell what you can or can't install depending on who's rules you run under.
Good luck!
Old 10-08-2006, 05:18 PM
Cobra Make, Engine: Autocraft MKIV
Default Suspension set up
Yes, there are books ... but there are many factors involved with setting up suspension. It is being set up to do what ?? street, track ( which track ?) road race or drag race.
Where you located ??
Old 10-08-2006, 07:47 PM
JCoop's Avatar
Cobra Make, Engine: Superformance, FRP460 Big Block
Anti sway bars front and back are a must for a car that plows like the Çobra on a AutoX course. Also, forget AutoXing the car if it doesn't have LSD. You'll probably be in with the Vette ZO6 and the Lotus Elise. They're tough to beat on short windy courses like an Autox.
First off, you should get the corner weights of the car fairly equal or close to from L to R. Tires are also pretty important in relation to suspension setup. Negative camber (up to 1.5 degrees) may be desireable, and 0 toe up front and 1/8 out in the rear.(this would be too darty on the street)
Drive the car and try different settings. Keep a log, and foremost, have lotsa fun.
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
Old 10-10-2006, 06:35 AM
RACER X #99's Avatar
Unless you have the necessary equipment to properley set up your car take it to a shop that specializes in track setups.Once you have the car properly aligned,balanced with correct corner weights, bump steer corrected, then you can hit the track and start taking notes.No shop can set your car up to perform perfectly the first time out, it requires patience and lots of tweaking. But you do need a base to start from and that you can get from a quality road race shop.
I don't where you live but if you live in the NY area
I can recommend this shop in NJ,
http://www.gsautoworks.biz/gs.htm
I use this shop for chassis work and they are great. I have sent lots of Cobra guys there and all are very happy with their work and prices.
See this post,
Roadrace shop in NJ
Good Luck.
Roger D
SAAC member and supporter
Club Cranky charter member
