Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
Old 08-17-2010, 04:29 PM
Cobra Make, Engine: Contemporary Cobra
Default best way to install carpet over dynamat
what's the best way to install over the foil side of dynamat?
Jon
Old 08-17-2010, 05:07 PM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
when i built my factory five roadster i used 3m super 77 spray adhesive over the dynamat then i also sprayed the back of the carpet. ffr uses a lot of cut pieces of carpet so your lnstallation may be different?.
Old 08-17-2010, 05:26 PM
Dwight's Avatar
Smile
spray adhesive
Dwight
Old 08-17-2010, 08:12 PM
Rwillia4's Avatar
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
3M super 77 spray works well ...watch out for the overspray it is sticker than snot.
Old 08-17-2010, 08:29 PM
I went with commercial grade velcro. Three inches wide if I recall correctly. Excellent glue on the side you glue down and very tenacious velcro locking power on the other side. Works for me...
Old 08-17-2010, 09:12 PM
car4jim's Avatar
Cobra Make, Engine: Kirkham, 427 side oiler
I used Weldwood Gel Contact Cement. The hi VOC stuff. I cleaned the foil well with lacquer thinner prior to application. Seems to stand up to the heat in the foot boxes well.
Old 08-18-2010, 03:08 PM
Okiesnake's Avatar
Cobra Make, Engine: Unique 427SC, 351W
The 3M or other brands of spray adhesive work well. The easiest thing to clean up any overspray is actually charcoal lighter fluid. The charcoal lighter fluid won't hurt any paint, vinyl or carpet. It disolves any adhesive overspray immediately.
Rate This Thread:
