Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
February 2026
Old 09-03-2010, 05:45 PM
Default 289 and t5 question
I am getting the drive train together. I just purchased a rebuilt 289 with a six bolt main. Will a t5 transmission from a 94-95 mustang bolt up if I get the year correct bell housing or would the 87 - 93 be easier. I think the 94 has the longer input shaft and the electronic speedo. I am just looking for a combination that will work.
Thanks
Old 09-03-2010, 05:55 PM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
I have a 71 302 with a 95 T-5 trans, bell housing, and flywheel. I had the flywheel rebalanced for a 28 oz. that they used in those years. I thought 95 was the year they were longer.
Old 09-03-2010, 06:22 PM
Cobra Make, Engine: Contemporary Cobra
Thanks
call mike forte.....508-875-0016 he will have the correct information
Old 09-03-2010, 07:38 PM
Cobra Make, Engine: B&B Mfg with '66 289ci
I have a similar setup (1966 289 with a 1990 WC T5). The 94~95 T5's have a different length input shaft on the trans. I know as I have rebuilt many. Save yourself some trouble and get a 87~93 world class T5 with a 86~93 5.0 bellhousing. You can use the 28 oz flywheel on your 6 bolt block and everything will bolt up. Brian
Old 09-04-2010, 10:57 AM
I don't have the flywheel yet, so I can buy one that matches. I can get a better deal on a 94-95 right now but if it is too much work I can wait for an 87-93.
