Old 10-03-2012, 05:01 PM
Default Electrical Problems
Having issues with turn signals after reinstalling the dash. Wiring harness is from EZ2Wire and switched by a VW turn signal...they worked fine before. When I turn them on either right or left all four are flashing and when I disconnect the right rear the left side works and if I switch to the right side then the left front works. The emergency flashers aren't connected....have to connect the ground. Any thoughts?????
Jon
Old 10-04-2012, 02:52 AM
Default Sound like a ground problem
Saltshaker Jon sound like a ground problem or a broken turn signal switch. What did you change in the car?? Depending on steering columns, it's possible you lost the ground clip inside the steering column and that this is a back feed. Check repair, possible pinched wire. Rick L.
Old 10-04-2012, 03:03 AM
Rick, interesting thought...I never hooked up the ground on the tail lights!
Jon
Old 10-04-2012, 08:26 AM
FWB's Avatar
FWB FWB is offline
diagram
Fred B
Old 10-04-2012, 03:40 PM
RallySnake's Avatar
You have somehow shorted the left and right side together. You need to go over your connections very carefully comparing them to the wiring diagram.
RS
