Like Tree1Likes
  • 1 Post By PNJSNAK
Old 09-06-2016, 07:25 PM
Cobra Make, Engine: Antique & Collectible Autos, Inc.
Default Anyone know what these are?
Old 09-06-2016, 08:24 PM
YerDugliness's Avatar
Could it be a cradle for mounting something like an IRS pumpkin? Those square plates look like the cutouts are sized to accept the ends of large angle iron mounting bracket and that assembly looks to be approximately long enough to mount between the frame rails.
If not, I'm clueless, as usual
Cheers!!
Dugly
YD,E./PNB
Old 09-07-2016, 06:24 AM
Cobra Make, Engine: Antique & Collectibles, Forte 427 SB, TKO 600
The flat plates with the "L" shaped cut out go in the trunk and cover the section of the floor thats cut out where your bumperettes/quick jacks mount.
The other 2 pieces look like they might be the mounts for the rollbar.
Old 09-07-2016, 06:33 AM
PNJSNAK's Avatar
Cobra Make, Engine: A&C 427S/C, 351W, T5
H-Rod is correct
The two metal brackets are for the roll bar mounting
I felt the roll bar was not tall enough, so I had made some extension pieces.
They were made from 1-3/4" heavy wall tubing with one end turned down to fit inside the roll bar ends and welded on.
I am trying to remember I think I added 3" or so.
This way it conformed to the rule about top of roll bar to top of fender straight line, your
The top of your noggin needs to be under the line.
cdnus likes this.
OhioCobraClub.com
Old 09-07-2016, 09:16 AM
1985 CCX's Avatar
It's a phister which connects to the cunooter
Old 12-12-2016, 07:35 PM
PNJSNAK's Avatar
Why?
I did not want to respond before, but really, why?
OhioCobraClub.com
