Old 03-26-2025, 08:45 PM
Default Radiator Question
I installed the lower bracket per the manual. I then rested the radiator that I got from A&C, with it the leaned forward, resting against the bottom tabs. The outlet for the radiator looks to be an issue. The hose will run right into the steering column boot. Simply, I don’t have the clearance needed. Has anyone has this issue, and what was your fix? I’m thinking about seeing if I can get the radiator outlet changed to a 90 degree.
Old 03-26-2025, 08:54 PM
Another angle
Old 03-27-2025, 06:32 AM
DanEC's Avatar
That obviously isn’t going to work. I know nothing about A&C but maybe they will address it if they can be contacted. Otherwise a radiator shop might/should be able to modify the outlet
ERA 782 Running
Old 01-17-2026, 01:43 PM
Roscoe's Avatar
Looks like it's on the wrong side. On my build the outlet is on the passenger side Check my old build site at www.priveye.com/cobra.htm
Roscoe
Old 01-17-2026, 01:45 PM
mrmustang's Avatar
Gold Star Contributor
Greetings Roscoe, nice to see you out and about.
Bill S.
Old 01-17-2026, 01:52 PM
Roscoe's Avatar
Still alive and kicking. Retired now in Jackson, NJ on a golf course. You know we lost Bill a few years ago, Miss him. Olsen is down in NC. Warm regards to you,
Roscoe
Roscoe
Old 01-17-2026, 01:54 PM
Roscoe's Avatar
Bill,
I'm looking at my stats here and I can't believe it's been 25 years from when I first signed in at CC
Roscoe
Old 01-17-2026, 08:00 PM
Looks like it's on the wrong side. On my build the outlet is on the passenger side Check my old build site at Cobra Project Page
Thanks. I looked. The outlet is on the side of the water pump return, so it’s on the right side as far as that goes. I bought the radiator from Ron, and it’s supposed to be match for the kit. I need to get some rubber radiator pads. Maybe that will lift it a little bit.
Old 01-22-2026, 12:24 PM
PNJSNAK's Avatar
Cobra Make, Engine: A&C 427S/C, 351W, T5
Roscoe, it’s been a long time since we spoke. I finally sold my car this past summer, 25 years. Do you still have your ride.
OhioCobraClub.com
Old 01-22-2026, 12:28 PM
PNJSNAK's Avatar
Maximus
Return the rad to A and C, order a special one from Griffin.
You can specify were you want your outlet on the bottom, and size, location, direction.
You don’t want a fill on the top, you do want a drain petcock on the bottom and I added on e on top to get the air out of the system
OhioCobraClub.com
Old 01-22-2026, 04:03 PM
Cobra Make, Engine: built the molds and body composite construction
Rather than a top petcock consider having them tap for a #4 AN fitting and run a AN PTFE line back to a mounting high on your fill tank. Just a suggestion.
BillK
