Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
February 2026
Old 07-04-2006, 06:16 PM
Cobra Make, Engine: Antique & Collectible
Default Clutch PLEASE!!!!!!!!
Almost finished. Just have to complete the clutch installation. I bought everything Joe T. said in the manual but I am having an issue with the set up. Even a picture of the slave set up would help.............
It's a T5. Anyone use anything different as far as a clutch is concerned?
Old 07-11-2006, 08:26 AM
Really need some help here guys...............Please
Old 07-11-2006, 09:10 AM
Cobra Make, Engine: Midstates/Antique Collectable
Try this site. Fortes is very good with products and questions on T5 trans & slave units. I would give them a call. They are a supporting vendor on the Factory 5 site.
http://www.fortesparts.com/
Old 07-11-2006, 01:40 PM
Cobra Make, Engine: A&C- 351w 5spd
You also might want to look at autoworksracing.com. I used their set-up and I'm completely satisfied. Little pricey $$$ but a nice product.
Old 07-12-2006, 06:56 AM
Roscoe's Avatar
I've got a Tremec 3550, basically a T-5. I'm using a Tilton hydraulic throw out bearing on a Centerforce Dual Friction clutch. This setup has over 25k miles on it. A recent engine rebuild revealed that the clutch plate had little or no wear on it.
I went with the hydraulic bearing because of the ease of setup. Couldn't be happier.
I also have a Tilton floor mounted pedal set.
Roscoe
Old 07-13-2006, 04:43 PM
Thank you for the assistance. Problem solved. I really appreciate it.
