Old 05-20-2007, 02:18 PM
Cobra Make, Engine: A&C 351W
Default Tires picking up rocks
Has anybody ever tried to put anything like a rubber mat or pad up inside the fenders to absorb the impact of a rock or road debris getting picked up by the tires and slung into the fiberglass body. I know the body is thick but sometimes if you get the tires hot you can really hear stuff slamming under there. It just makes me worry one of these days its going crack the paint on the top side.
Old 05-20-2007, 04:04 PM
jerry w's Avatar
Cobra Make, Engine: Antique & Collectable 302, C-4,Ford 9 inch
I used a 3M poduct I got from my autobody/paint supplier. (Sorry I do not have the reciept to give you the product name/number) It came in a spray can, and put a rubbery absorbent black coating on my fender wells. Seems to work well. when a stone gets tossed up, it goes "thud" rather that than "crack". I have only had it on one summer, time will tell how well it works.
I recall a thread about this subject in another part of the forum, worth a search.
Best Regards,
Jerry
Old 05-20-2007, 04:08 PM
Tony Aprile's Avatar
Cobra Make, Engine: SPF #1358 Silver/Black stripes 466 2X4
Default Inner fender protection
Try this thread
http://www.clubcobra.com/forums/show...732#post742732
Old 05-21-2007, 11:33 AM
Roscoe's Avatar
Spray undercoating. deadens sound too.
Roscoe
Roscoe
Old 05-22-2007, 05:57 PM
Bob In Ct's Avatar
I just put 2 test pieces of neoprene (5/16) on my SPF. The material is that used by Top of the Hill. I put one piece on according to instructions. The second piece I applied 3M adhesive on the fender first and then applied the neoprene. I'll let you know on 6-15-07 how they look.
If it's still tight I will allow the guys at Top of the Hill to over-charge me for the kit.
Old 05-22-2007, 08:04 PM
richsd's Avatar
Cobra Make, Engine: 427 Cobra re-creation based on Kirkham aluminum body and chassis, Original 1965 Ford 427 Side Oiler and Ford Toploader transmission
Yes this is a typical step with original Cobras because rocks hitting aluminum make for some interesting dings. Some thin rubberized foam padding applied to the inside of the wheel well is the way to go.
