Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 07-10-2007, 08:48 PM
Default Help!!!-ignition problems-1965-427
It can only happen to me. Went to try and start it today. Started to turn it over. After about 3 tries, i turn the key off and the starter continues to turn over. What the heck. So i turn my cutoff switch off. Starter stops. I have no keys in the ignition switch and i turn on the kill switch. Well there goes the starter again. This time when i turn the kill switch off, The starter continues to run. Yes, run. So i hurried and disconnected the battery. Removed the switch and put a tst light to it and it seems to be ok. Put it back together again without the key and attached the battery again. No starter operation, good. Put the kill switch key back in and the starter starts to engage again with no keys in the ignition switch at all. Is it possible that the new fender mounted ford solinoid switch is stuck open? Or is it the ignition switch itself that came with the American Autowire kit?
But heres the thing, through out the whole wiring installation, no problems. Utilized the kill switch to test wiring completion. Everything functioned o
Just dont know what gives.
Help
Automan
Old 07-11-2007, 03:30 PM
jerry w's Avatar
Cobra Make, Engine: Antique & Collectable 302, C-4,Ford 9 inch
I would start with your ignition switch. I am not there to see your wiring, and it is sometimes hard to find your own mistake. Also call American Autwire. I used their harness, I had a question and called them, they were helpful. Good luck, hope you find the fault quickly, keep us posted.
Regards,
Jerry
Old 07-11-2007, 04:11 PM
FFR428's Avatar
Cobra Make, Engine: HM-2027 / 427 SO
It does sound like the solinoid stuck open. I've had the same thing happen and in my cases that was the problem.
G.
