Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
Old 09-04-2007, 01:20 PM
Default 427 Blues
Well: it was early Sunday morning at 500am and i decided i would take the cobra to work. Things are going smooth. Doing 60 miles at 2200 RPM. 355 gears in the rear. Look in the rear view mirror and i see some white smoke coming from my right side. Take my foot of the gas and then back on to see it disappear. Don't trust the gas gage yet so i pulled into the gas station and filled here up. Went to start her up and nothing. Just a WHA WHA as if the starter was extremely tired. Called the wife for the booster. That went over really well. Hooked up the charger and the same thing. My brotherinlaw comes and we try to jump start it. Nothing. but then suddenly it starts when i go to turn it over by the key. Brother starts waving his hands for we to shut her down. Calls me over, i get out to see the drops of antifreeze dropping out of my side exhaust. What the ----!!!
Tow it home and call the engine builder. He says for me to tear it down, rmove the head and he will come over and see whats happening. He's coming over tonight.
Things that i seen. Head gasket looks torn right infront of the number 1 piston. Both sides. Over top of the big water jacket. The Push rod, top dome that sits underneith the adjust is broken. The broken piece was sitting right on top of the head. And the end bolt by the cylinder that was filled with water(because the piton head is clean compared to the other 3)didn't have the torque like the otherones.
Im almost done.
Old 09-04-2007, 01:43 PM
Cobra Make, Engine: SPF 545" stroked 460 - sold
Automan, that was too painful to read, the blues for sure. I hope it is a quick fix and you are back on the road soon
Old 09-05-2007, 03:07 AM
Rebuilder came over last night a determined that the cause was pre-detination. He took both heads to make sure that they are still in good conditon and flat back to the shop. He will be ordering all of the gaskets and the one pushrod. No damage done to the block. The plan is to put her back together this Saturday with the Holly carb guy also there. They will make sure that when they leave that the car will be runnng like she should be.
On all of the cylinders, you could see that the black carbon was getting by the surrounding cylinder head gasket seal. The driver side head gasket also had the same tear as the passengerside. It was just a matter of time before i drowned out that cylinder too.
Learning alot but at a great deal of expense.
Automan
Old 09-05-2007, 05:31 AM
Cobra Make, Engine: A&C
Good to hear!
What octane gas were you using? What was the compression ratio? I'm planning on 9.5 and using 91 octane.
RDC
Old 09-06-2007, 06:12 AM
Compression ratio is 11:1. That was one of the problems. That i was using the cheap gas. I have to use the high octaine gas only for now on. I threw in a can of octane boost into the tank for when i start it back up hopefully this weekend.
