Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 12-03-2007, 08:40 PM
Cobra Make, Engine: A&C
Default 9" axle bracket order for svo brake
This doesn't look obvious to me. I like to get it right before I get them pressed on. Is this the right order for the brackes and bearing for the axle?
I have to open up a bit the svo brake bracket opening to slide over the bearings (dermel). I talk to Joe at A&C and I think this is what he was explaining to me. ????
small bracket , svo brake bracket, bearing , thick retaining washer.???? !!!
Old 12-04-2007, 07:29 AM
Cobra Make, Engine: A&C, Stroked 408, TKO 600
I got my rear disk set up from A&C and no problems getting the bearings to clear the backing plates. I.E. the only thing I had was the four bolt axle retainer, main bearing and then the bearing retainer.
Thanks,
Jim
Old 12-04-2007, 09:28 AM
Rick Parker's Avatar
You can eliminate the disc brake dust shield entirely and get brackets that either weld to the axle tubes or bolt to the bearing retainers. The dust shields are/were used in OEM applications to keep rain, mud, excess dirt off of the rotors. Not too useful on our cars.
Rick
Old 12-04-2007, 09:56 AM
Cobra Make, Engine: A&C 460
I could be wrong, but I think you are missing a spacer that takes up the thickness of the bracket/plate. It goes on between the retainer and the bearing. Mine was not put on first and I had to split it in two. Made it extremely difficult to assemble. Mike
Your retainer is different than mine, this may be part of your retainer
Old 12-04-2007, 10:35 AM
gman
I think your right . Just eyeballing the how far the bearing goes in and the thickness of the brake bracket there is a space. I need a thick washer.
RDC
Old 12-04-2007, 03:20 PM
I called the "the9inchfactory" 1 800 332 3450 and they had the right spacer for the svo brake bracket. 10 bucks.
Old 12-04-2007, 07:03 PM
Glad I could help. Mike
Old 01-19-2008, 07:11 PM
VINCENT RUDI's Avatar
Cobra Make, Engine: ANTIQUE AND COLLECTABLEFORD 460
Don't forget your seals and be carefull when you put them in a piece of pvc plastic pipping works great good luck
