Old 01-17-2010, 09:17 PM
DWRAT's Avatar
Default Brake calipers ???
Why do I have 4 bleed screws on each brake caliper?
What a pain in the but to bleed the system but it is done and now my rears appear to be working.
Dan
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
Old 01-17-2010, 09:20 PM
mickmate's Avatar
Top and bottom, inner and outer. That's so they can be mounted left or right and you have a bleeder at the top where you need it.
mickmate
http://www.actoncustom.com/
Old 01-17-2010, 09:29 PM
DWRAT's Avatar
So does that mean I only needed to bleed the 2 top screws?
FFR MK1---Sold
No more Furds.
Old 01-18-2010, 03:02 AM
Default Only crack the top ones, Dan
DWRAT Dan the calipers are universal that they can mount on the right or left side of the car. Just do the tops on all and you will be ok. If you have a plastic or rubber hammer, tap on the calipers 5-7 times each. This is to help get all the air out of the calipers before you start driving. After you do a drive and get back bleed the system one more time and watch to see no air bubbles in the fluid. Rick L.
Old 01-18-2010, 04:51 AM
Dan
I suspect that you have four to allow the calipers to be mounted in different locations either in front or back of the wheel center line. That said, air goes to the top of the piston bore and the upper bleed screws should be used (because that is where the air is).
Display Modes
