February 2026
Like Tree3Likes
Old 04-18-2014, 06:31 PM
Shootnride's Avatar
Cobra Make, Engine: Superformance, 427SO
Originally Posted by Car Nut View Post
Attachment 23648 I have the SR's on this.
Man, that Falcon looks like it just came off the showroom ! Oh wait........I think I spotted a few modifications
Old 04-18-2014, 06:38 PM
Cobra Make, Engine: ERA 427 S/C W/Holmon Moody Original Nascar build #508 Iron Block/heads (C5AE-H) Bal/Blu 427 Sideoiler; 780 Holley Dbl. Pump; 4 Speed Top Loader; AP Racing Bks; IRS; 15" Trigo pins
Originally Posted by DWRAT View Post
Did Danr figure those percentages?
Nope, just a 4 place scale! What you don't like my math? hehe Always someone has to be a sticker!! f 49.7 r 50.3 happy now
Old 04-19-2014, 04:11 PM
DWRAT's Avatar
The 28-12-15 MT SR's may be to big I think.
There the same height as the factory 275-60-15 and the same width as a 295-50-15.
I think they might rub on the outer edges???
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
Old 04-19-2014, 06:19 PM
Karl Bebout's Avatar
"I think they might rub on the outer edges"
Depends a bunch on your wheel offset and your fender profile . I run 325.50.15s on the rear and I don't have any interference.
Karlos
Old 04-19-2014, 11:20 PM
Default MT and Cooper Tire Comparison
Originally Posted by Monster View Post
I have 15"'s
I had MT S/R's on my car (rear) and really liked them but I only got about 13K miles out of them. So I decided to go with more of a "street" tire. I was going to go with the MT S/T then I found out Mickey Thompson is owned by Cooper. The Cooper "Cobra" radial appeared to be the exact same tire as the MT S/T (tread is identical) and they were about $50 less so I went with the Coopers.
I'm not happy with my choice, the Coopers feel "soft" in the sidewall and I can feel my car moving side to side (wondering) while driving. Now I am wondering if the case from MT S/T may be stiffer than the Cooper Cobra and the two models just share tread design. I don't have any way of telling, I just know my car felt better with the MT S/R's.
I don't know that I want to make a $450 experiment to find out if the MT S/T has a stiffer side wall than the Cooper. If it does it might be a good option for those who do mostly street driving and need a 15" tire.
hope this helps some,
mike
One way you may be able to confirm your suspicion that the tires are the same, with only a different label, is to compare the Uniform Tire Quality Grading (UTQG) of the two. These are the Treadwear (number), Traction (letter), and Temperature (letter) ratings on the sidewall. While these may not tell you anything specific about the sidewall stiffness, if they are identical on the two tires, and made by the same manufacturer, then chances are, they are indeed the same tire.
Some other comparators that you should be able to find on the tires or on website information (Tire Rack, Discount Tire, or mfg.) are where they are made, the maximum load, maximum pressure, and the number of plies in the tread and sidewall. This may also give you an indication of sidewall stiffness. I haven’t researched this to say for sure, but I would think if a tire is rated for a heavier load, and of course if a sidewall has more plies, it should be stiffer.
But again, if ALL of these parameters of these two tires are identical, and they are made by the same manufacturer, it may indeed confirm your suspicions…..and be cheaper than a $450 experiment. And as further confirmation, before spending the money with the uncertainty, call or email Cooper and MT and ask them if they are all the same company, and if the tires you are interested in are the same tire. Again, cheaper than a $450 experiment.
If a man does not keep pace with his companions, perhaps it is because he hears a different rumble. Let him step to the sidepipes which he hears, however measured or far away. - H.D. Thoreau...if he had owned a Cobra
Old 04-20-2014, 06:49 AM
blown871's Avatar
Cobra Make, Engine: SPF
Also ask yourself; "true use of the car? and budget"
I just got tires from TireCrawler. Had never used them and saved even more $ and they were delivered on time.
Old 04-20-2014, 03:18 PM
mikiec's Avatar
I agree with Blown871. depends on your use. strictly street, then I don't think you need super sticky tires. For 14 years I have been using the BFG's. Radial TA's. Suit me just fine. I don't race and almost no spirited driving no runs over 100 MPH.
Old 04-20-2014, 11:37 PM
Danr55's Avatar
Mikie, Is you nose growing again?
Dan in Arizona
CCX3209
Old 04-21-2014, 12:33 AM
750hp's Avatar
If you go with the Mickey Thompson SR, you need the 26x10 and 26x12 tires (part number 6653 and 6654).
Craig
Old 04-21-2014, 06:41 AM
mikiec's Avatar
Dan... SHHH just trying to slow down Ratboy.
Old 04-21-2014, 07:32 AM
DWRAT's Avatar
The 26X12 tires are 1" shorter then the 295-50-15 tires which are 1" shorter then the stockers.
I'm just going to wait until I can measure the fender clearance.
I really don't want a short tire if I can get away with the taller tire.
FFR MK1---Sold
No more Furds.
Old 04-21-2014, 07:38 AM
DWRAT's Avatar
Believe it or not you already slowed me way down a few years back.
Or maybe it was my tires that turned to butter that taught me that?
Either way i'm still kinda gun shy of lighting them up.
FFR MK1---Sold
No more Furds.
  #33 (permalink)
Old 04-21-2014, 10:20 AM
That'll change. On the SPF when using the SR tires Craig is right. 26X12 rear and 26X10 front. My choice is the ST 295/50 rear and 255/60 front. Looks right. Ride height can be adjusted.
AZ Bob
  #34 (permalink)
Old 04-22-2014, 12:10 PM
Fitz's Avatar
Cobra Make, Engine: FFR Mk 3 408 530 - 585 T- mustang Dyno at B&R
"".Get passed what everyone 'thinks' looks right.
Do what makes YOU happy.
It is a performance car. Try a performance tire.""
I have used 18" Sumo's, Mich.. PS2's and now Bridgestone's Potenas. They are all fine on the street until you hit 10,000 miles. On the track all tires are crap unless you go to a track tire.
Fitz
fitzus1@gmail.com
  #35 (permalink)
Old 04-22-2014, 04:42 PM
blown871's Avatar
Going from 15 to 18
Rims to match.
  #36 (permalink)
Old 04-22-2014, 05:05 PM
Hey, Mikie would love those.
AZ Bob
  #37 (permalink)
Old 04-22-2014, 05:13 PM
DWRAT's Avatar
Originally Posted by blown871 View Post
Going from 15 to 18
Rims to match.
What kind of price for 18" wheels???
FFR MK1---Sold
No more Furds.
  #38 (permalink)
Old 04-22-2014, 05:37 PM
blown871's Avatar
Vintage Wheels, Hot Rod and Muscle car
  #39 (permalink)
Old 04-22-2014, 05:45 PM
DWRAT's Avatar
I like my 15" wheels even more now.
FFR MK1---Sold
No more Furds.
  #40 (permalink)
Old 04-22-2014, 06:01 PM
blown871's Avatar
yes.. not cheap.
.. but again.. get what tire will make YOU happy. It is supposedly a performance car.. so throw some performance tires on it and enjoy!! And NO.. performance tires don't last. Accept that and smile every mile and every turn.
