3Likes
04-22-2014, 07:27 PM
Cobra Make, Engine: Superformance, 427SO
Originally Posted by Bob Broberg SPF667 460BB
That'll change. On the SPF when using the SR tires Craig is right. 26X12 rear and 26X10 front. My choice is the ST 295/50 rear and 255/60 front. Looks right. Ride height can be adjusted.
AZ Bob
This is my SPF with the 26x10 on front and 28x12 on the rear. Rears are very close but haven't been a problem with about 3000 miles on them.
Ted
06-02-2014, 08:16 PM
Well after looking at many different tires I finally decided on and ordered Mickey Thomson Sportsman S/R tires.
Front tires---26/10/15 which are about 1" shorter and the same width as the 255-60-15.
Rear tires----28/12/15 which are the exact same hight but 1" wider then the 275-60-15.
Anyone want to buy some like brand new 14 year old tires?
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
06-02-2014, 08:52 PM
Ratty tat tat, Let us know how you like the MT Sportman's SRs. I've certainly been pleased with my MT Drag Radials. I'm on my second set but I may just hold on to them for the strip and put something with a Leetle more tread for street use.
Karlos
06-07-2014, 02:40 PM
Perfect,
Just what I wanted.
Rears-28-12-15 are a tad bit taller then the 275s and 1" wider.
Fronts-26-10-15 are about 1" shorter but the same width as the 255s.
FFR MK1---Sold
No more Furds.
06-07-2014, 02:42 PM
ny
Cobra Make, Engine: SPF
now yer talkin!
06-07-2014, 04:39 PM
There on and fit well.
Thanks for all the helps guys.
BTW, does it look like my safty wire is installed correctly?
FFR MK1---Sold
No more Furds.
06-07-2014, 04:43 PM
Here's a better picture of the safty wire, does it look OK?
FFR MK1---Sold
No more Furds.
06-07-2014, 10:41 PM
If that is the driver's side, Looks fine. Mirror image on passenger side. Those tire treads look real sticky. Enjoy.
AZ Bob
06-08-2014, 05:36 AM
Yep, correct for driver side. Passenger side should be opposite direction. Surprising how many get that wrong. Enjoy the SRs, great street tire.
06-08-2014, 10:18 AM
Tested out the tires this morning and they did very well.
They stick extremely well at 20 psi, I fell like I'm gonna break something in the drive train now.
First tank of fuel ran through it and it only got 10 mpg so far.
Hopefully on the road it will do better.
FFR MK1---Sold
No more Furds.
06-08-2014, 01:27 PM
Dan, 10MPG is good for a real Cobra Motor.. Anything more than that and, with a few exceptions, you're pretending..
(That should raise a few eyebrows!)
Dan in Arizona
CCX3209
06-10-2014, 07:04 AM
I'm pretending.
06-13-2014, 01:41 PM
Az
Cobra Make, Engine: FFR MK3/302/570 street avenger
