| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
1Likes
Post By Karl Bebout
01-02-2017, 10:29 AM
Az
Cobra Make, Engine: FFMK2
Broken Cobra Transmission Back....About Time
Finally got the trans back and he sent the broken pieces back ,,Thank god for warranty's. We will be rolling soon .....
01-02-2017, 10:45 AM
Looks pretty bad.
What Trans? Did they give you root cause?
You have 2 broken parts shown. What are they and did one take out the other?
Thanks
01-02-2017, 10:59 AM
AZ
Good. What about the new car? When can we expect to see that?
Dan in Arizona
CCX3209
01-02-2017, 12:31 PM
AZ
DAMNTIME, loafer!
Karlos
01-02-2017, 04:54 PM
Az
Originally Posted by spdbrake
Looks pretty bad.
Thanks
The trans was a AOD ,with 2500 stall and full lock up and a fully reworked valve body,hold any gear. With push button to disengage the OD. It was the main pump shaft and main shaft and the one that has no gears left was the lock up gear on toque convertor ,they said they never seen anything like this ,,the trans was built for 600tq ---500hp. I was into my first year of my 3 year warranty ,I will take it easy ...( for a week)
01-02-2017, 05:03 PM
Az
Neutral
Here it is ,fun fun
01-02-2017, 05:21 PM
AZ
Isn't that Al W.'s RCR?
Alba gu brąth
01-02-2017, 06:04 PM
Cobra Make, Engine: All original, with Chevy engine since 1964
Al, when Danr first showed me the pics a couple weeks back, I thought it was a Saleen, but it's actually a Superlite, right...?
- Robert
01-02-2017, 06:21 PM
AZ
Cobra Make, Engine: Ex owner of a polished Kirkham 427 S/C. Now Cobra-less and driving a mid-engine German hot rod.
Cool new car! Wow!
That smaller diameter shaft looks like a classic torsion failure. Assuming it was not a material defect or overloaded, it may have been a fatigue failure due to some sort of high frequency torque oscillation but hard to understand what may have caused that. Hope the next one holds up!
01-02-2017, 06:48 PM
Az
Lemans kit car
01-03-2017, 07:09 AM
Very cool-
I just checked out Superlite's website- I didn't realize they had so many different models now.
Whatcha got in there? LS7?
- Robert
01-06-2017, 11:26 AM
IL
Cobra Make, Engine: FFR, 347, 462 hp, 4 barrel
Hard to tell root cause on rotating shafts. The broken parts rub together and this often destroys much of the evidence.
One does look like high torque based upon the 45 degree failure. The other could be stress concentration due to a small radius at the transition between the shaft and gear. However type of material or heat treatment could also be a cause.
Since your trans can hold each gear, this may have contributed to the failure but not the root cause. Suggest you let the auto do it's own shifting for a while.
Lee
01-06-2017, 05:02 PM
az
Cobra Make, Engine: FF5 347 stroker
Did they harden the new parts so this will not happen again. I recall that is why it took them a while to rebuild. Makes sense. Have you had time to install?
Gary
01-07-2017, 06:30 PM
AZ
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
Hey Al, we're going to be fairly close to your home base tomorrow, why don't you join the group for lunch.
If you can't make it, send your wife, I miss her!
Ralphie
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
