2Likes
05-18-2017, 08:34 AM
Az
Cobra Make, Engine: FFR MK3/302/570 street avenger
Payton Breakfast Run-Saturday May 20th
We are meeting at the Shell station in Fountain Hills this Saturday for an 8:30 am blastoff to the Payson airport restaurant for breakfast. Be there !!
Last one up the hill buys !
05-18-2017, 09:55 AM
I'll be there.
No I won't
I'll be there.
No I won't
I'll be there
No I won't
YES, I'll be there....
Must have gotten an overdose of estrogen.
Karlos
05-18-2017, 09:59 AM
Cobra Make, Engine: Ex owner of a polished Kirkham 427 S/C. Now Cobra-less and driving a mid-engine German hot rod.
The I will be there
05-19-2017, 06:32 AM
Cobra Make, Engine: All original, with Chevy engine since 1964
Scotchman
Karlos
Mark and Lisa
FIA FlyBoy
Greg and Vicky
The Tooth Doc
The King of Spray and Wipe...
and me.
anyone else?
- Robert
05-19-2017, 08:21 AM
"Maybe" nniets and "Maybe" Superstition Bill, but I'm not holding my breath.
Karlos
05-19-2017, 08:36 AM
az
Cobra Make, Engine: ERA FIA, 396 Windsor Stroker (Formerly: Unique 427 powered by a 351W with mysterious innards)
Go ahead, hold your breath...
The old saw says ‘If you want a thing done right, do it yourself.’ The true statement is ‘If you want it done your way, do it yourself.’ There are many flavors of ‘right’.
05-19-2017, 10:38 AM
Cobra Make, Engine: FFR MkIV 427
Maybe Jim too. He has to see if he is up to it.
05-19-2017, 09:31 PM
I'm out...
Wife came home from work with strep throat - she is down for the count. I'll be taking care of the kids tomorrow, and they won't both fit in the car...
- Robert
05-20-2017, 07:06 AM
RB, sorry to hear that you wife is ill. Don't be swappin any spit with her.
You're going to miss seeing "Walter".
Karlos
05-20-2017, 01:02 PM
Cobra Make, Engine: ERA 289 FIA #2114
Great day for a drive up to Payson, the Crosswind was full and we had to wait a bit but the food was good as usual. Some bikers Scottie met at the service station put Scotties name on the list for a group table when they arrived and that saved us some time as we didn't have to wait as long to be seated. Nice guys! We scattered in about three different directions on the way home but I'm sure all had a good drive home. Have a good drive home Greg and Vicki, see you next winter.
05-20-2017, 01:28 PM
Hope everyone made it back okay. It was a bit toasty coming into Phx.
05-20-2017, 02:14 PM
Cobra Make, Engine: FFR1983, 427W, IRS, Wilwood brakes
Great day, great drive, great people and great breakfast! What's not to like? Was a bit warm getting back to the valley, but a small price to pay for fun!
05-20-2017, 03:05 PM
232 miles for me today. I took the long way back from PaySon buy going down through Punkin Center, along Roosevelt Lake, over to Globe and then home. Nice little drive but the car developed a nasty vibration that is definitely drive train related. No vibration with the clutch in, revving the engine. Can feel the vibration when running through each gear and there is so much vibration at speed that I can't see with the rear view mirror. Got some investigating to do.
Karlos
05-20-2017, 03:24 PM
az
We took the same route, watching for you along the way, but never saw you. We were a good 20 minutes behind though, maybe more. Is the vibration the same in each gear, or does it get worse with speed?
05-20-2017, 03:38 PM
Az
Maybe a U joint Karl ? Hope it's an easy fix. Post pics for us, I'm home and bored already
05-20-2017, 06:39 PM
Hope you can sort it out easily and it's not a big deal Karl. If it's not vibrating sittting still with the clutch in, then (as you note) it's not the engine or flywheel. Sounds like it is shaking at various vehicle speeds as you go through each of the gears, so probably not wheel imbalance (since that would be limited to certain vehicle speeds, or get steadily worse as you gained speed). This makes me think it is transmission or clutch related. I would check the transmission mounts and u-joints and if all seems secure there then maybe the clutch disk?
05-20-2017, 10:50 PM
I feel the vibration in each gear and not when I put the clutch in to shift. I'm hoping for a drive shaft uJoint. Hope to find it tomorrow.
Karlos
05-21-2017, 10:43 AM
AZ.
Karlos, I banged my head against the wall over like conditions. U-joints seem to change if accelerating or decelerating with the load changes. The on/off affect of pressure plate seems like a clue to chase. Pressure plate or maybe a bad input shaft bearing on tranny?
05-21-2017, 01:45 PM
Check Your Muffler Bearings
No, don't thank me. Just trying to help here.
AZ Bob
05-21-2017, 03:35 PM
az
AZ Bob
The bearing looks fine - It must be the baffle races.
