4Likes
Post By Karl Bebout
Post By Karl Bebout
Post By undy
Post By nniets
01-07-2019, 01:00 PM
Club Cobra Badge Holders
One of the members in the Great Northwest has designed a badge holder specifically for the Club Cobra badges. He needs feedback to determine if they will fit universally. Please check these dimensions against your car and report back on the findings. The dimensions you need to check are the .75 diameter (the diameter of the tube around the bolts that hold the bump, overriders. quick jacks), and the overall height of the center to center measurement between the upper and lower tubes. If you check those, please post your findings here.
Dan in Arizona
CCX3209
01-07-2019, 01:32 PM
Dan,
Just FYI I don't need a badge bracket (see my post on the "other" thread).
I checked mine out of curiosity and found that the O.D. of my tubes is 3/4", same as the drawing.
The vertical distance between the tube centerlines is 2-1/4" which is 1/2" closer together than the drawing. Mine's an E-M from ~2000, so YMMV...
I'd suggest making the clamp dimension slightly more than 3/4" to make room for a thin band of urethane (or suitable wrap-around elastomer shim) to prevent metal-to-metal contact.
Tom
01-07-2019, 02:37 PM
Hi Dan,
Mine has 3/4" O.D. tubes, with the tubes centerline spacing at 2.25"
Juan
01-07-2019, 03:39 PM
WA
Thanks much Dan, for starting this post, one less thing I have do today. I believe the 3.50" center to center, is for mine and one other member's car up here. Classic Roadster's have that 3.50" and 1.25 dia. tubes, of course I have to be odd man out  So Skip will be making that size as well. These will finished in brushed alum. but can easily be polished for those that like that look (Me). Any other question's like price will be addressed shortly, after he does the first run, which will be done (Fingers crossed) by this weekend. Please contact myself, or Dan. Cheers Tom.
01-07-2019, 06:51 PM
Senior CC Premier Member
WA
Cobra Make, Engine: Everett-Morrison 514, Toploader 4 sp, Jag IRS
My EM car has 3/4" OD tubes and 2-1/4" tube centerlines, as per Tom Wells' EM noted above. I second Tom Wells' sentiment about designing to accomodate an appropriate soft shim (or surface) to prevent metal to metal contact.
Thanks, Brent
01-08-2019, 08:43 AM
My Kirkham has the 3/4" tubes and 2 1/4" centerlines while the CR has 1 1/4"
tubes with 3 1/2" spacing, same as Alfa02. I'd be interested in one of each, if
available.
Flip
01-08-2019, 07:44 PM
the kellisons are .75 tube on 5.062 center lines, i think making a bracket and marketing it will be a losing proposition, too many variables.
Fred B
01-09-2019, 04:55 AM
WI
Tom, I have a CR as well. would like the appropriate bracket as yours.
Thom
01-20-2019, 09:59 AM
Alpha Tom, anything going on these yet?
Thanks, K.
Karlos
01-20-2019, 10:33 AM
WA
"Alpha Tom", Carl  , you know better then that  In fact yes, I have news. Skip, myself and Dave (another club member) went last Tues. to Bruce's (Bruce Snyder) house to help install his "New" 347 in his Cobra. Skip and I talked, he said, we will have to do 3 different version's min. and will do any one badge holder at extra cost that doesn't meet the 3-"Standard" holders. Skip has made one for his car in Alum. to see final fit, like I said before he's still working at Boeing full time, and only has weekend's to work on the project, plus his buddy, has a better CNC machine, he will use his when time allows. Were getting there Karl, thanks for checking up on us here, in the "Great North Wet". Cheers Tom.
02-18-2019, 09:15 AM
Tom Tom....Any relation to the GPS?
What's the luv about the badge brakets yet?
I'm using this as an excuse to procrastinate about making my own (which would be substanially cruder than what Skip designed).
Karlos
02-18-2019, 05:13 PM
WA
Karl, I'll make a quick call to Skip tonight, and call you tomorrow, I spoke with Dan, and then our long lost "Rob" today, so it's only fair, I call you tomorrow, last on the Az. list  Cheers Tommy Boy. Waiting patiently for a smart ass answer from you, don't disappoint me now Karl
02-18-2019, 07:09 PM
Tom Tom " I'll make a quick call to Skip tonight"
I'm thinking that a "quick call" by you, is very subject to interpretation.
My turn tomorrow?
Karlos
02-19-2019, 05:10 AM
I modified a bicycle rear reflector that mounts under the seat that I had laying around the garage. With some minor work it provided a sturdy mount for my rear bumperette. It won't work for quick jacks though...
Too many toys?? never!
02-19-2019, 03:24 PM
az
Cobra Make, Engine: ERA FIA, 396 Windsor Stroker (Formerly: Unique 427 powered by a 351W with mysterious innards)
You might have to settle for an ass answer from Karl. I'm not sure he does 'smart'.
The old saw says ‘If you want a thing done right, do it yourself.’ The true statement is ‘If you want it done your way, do it yourself.’ There are many flavors of ‘right’.
02-19-2019, 05:55 PM
WA
Ok boy's I didn't have my normal hour+ phone call that I seem to make (Ask Bruce, Larry, Brent, Dan, Rob, Karl, etc.,etc.) . I asked Skip about the holder's, and do you have a (Good) excuse for not getting up to speed on them, "Well the Hospital almost killing me", was the best one he could up with  Long story, short he's recovering and at home. He said as soon, as it warm's up a little here, he'll get out to the shop. So boy's I guess we can give "Ol'Skippy a break.
I called you Mr. Bebout, I guess when you saw it was me, you let it go to voice mail  Not up for a hour+ phone call, buddy boy  Cheers Tom.
02-20-2019, 07:58 AM
Cobra Make, Engine: NAF 427
Hi guys. Another simple route would be to use Billet Specialties billet aluminum hose separators like this:
They come in many different sizes.
I used 1 inch hose sized separators and I cut one of the "holes" off to mount my front license plate to my front bumper so the plate would swivel back like the original 427 street cars. The center clamping screw holds anything you want onto a round tube. Add a little rubber sheet as a shim if you need to.
Looks like this:
Add a piece of flat aluminum bar to hold the badge and you're done.
Just another idea.
Greg
02-20-2019, 08:05 AM
Oh yeah and hose separators like this come in black plastic too if you don't want the shiney look.
Greg
