Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Arntz/Butler Forum
Old 10-04-2011, 03:10 PM
Murky781's Avatar
Cobra Make, Engine: ERA 781, 69' 428CJ, PPG BLACK. ERA 3005 Arctic White 331 SBF
wipers need power after the car is turned off to return to the down position. fans need power to keep cooling if the thermostat calls for it after parking.
We make 3 bad decisions a day. Choose them wisely.
Old 10-04-2011, 05:46 PM
lal Naja's Avatar
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Tommy & Randy, I hope you can see the diagram now.
Thanks to Craig-750hp for showing it.
And thanks for the input from you all, including Murky781. It prompted me to do a little more research.
First of all the Original key switch that came from Butler had the incorrect key. So I was locked out. So I went to a auto supply and got what looked like an identical key switch and swapped it out. Now I believe that I have a faulty switch for the following reasons.
1: With the key inserted and in the ON position the Ignition & the Starter terminals are live. This would have been startling and dangerous.
2: ACC is only live when in the ACC position. I agree with you guys that ACC should be live when the key in in the ON position.
I dismantled the original key switch by pulling out the tumbler and was able to do the same test using a screwdriver and the results are: In the ON position, Ignition & ACC are live. Starter only live in Start position.
With regard to wipers & fans. The car would have to have the key in, and in ACC position to operate those two components if that were the case.
My wiper motor has an extra positive feed going to a built-in rotary switch on the motor, and continues to supply power till wipers return to the rest position. The switch is adjustable and shuts off power at the precise moment. If you adjust it correctly that is
The fan is controlled by a nice module from Spal which has a direct feed from the battery + to allow the fan to run it's cool-down cycle. The Spal unit just needs an igition ON/OFF signal and temperature sensor. I'm not going to use the existing wire in my harness. The one from ACC through the fuse > fan (the one I Hi-Lit in blue on the diagram) I'll just save it for some other accessory in the future.
Please chime in if I'm getting any of this wrong.
This Forum is just great! I do not have any local gear head (Petrol head) friends to bounce these issues off. So thanks again to all for your comments.
Arthur
Old 10-04-2011, 09:51 PM
mreid's Avatar
Cobra Make, Engine: Kirkham 289 FIA #690, FRPP 427 Boss engine
BAAAAAAHHHP (that's the wrong buzzer).
It's actually backwards and while no one can account for someone elses logic, I'll bet they were deemed devices not required to start the engine. Your key should provide:
ACC: ACC circuits only
OFF: None from key (Only circuits powered by battery have power)
ON: ACC and ON circuits
START: Starting signal to solenoid and ON circuits
This is how your switch should work and it removes power to switched circuits not required to start the car or who may draw battery current away from the starter motor (items like headlights, horn, and brake lights are powered directly from the battery). Fan and wipers are not required to start the engine or for safety.
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
