Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Arntz/Butler Forum
Like Tree2Likes
  • 1 Post By mrmustang
  • 1 Post By Thor maine
Old 06-11-2013, 03:34 PM
Default Arntz/Butler Cobra?
Dear all,
I own a Cobra and I´m not sure if it is an early Arntz Butler car. I would be intersted in your opinion. The car has the MGB front suspension a Jaguar rear end. I think it was imported to Germany in the late 70`s but I´m not sure about that.
I try to attach some pictures! Many thanks in advance!
Thomas
Old 06-11-2013, 08:19 PM
Thor maine's Avatar
The frame Maybe ? But the body is not Artnz/Butler. They had no rear fender lip. More pictures please.
Old 06-13-2013, 09:33 PM
Junior Member
Cobra Make, Engine: 1980 Arntz 427W, Webers, TKO600, Jag IRS
The frame looks correct. 3x4 rails with a cross member under the engine. 1x4 out rigger frame under the seats. 4 to 1 collectors and square flange exactly like mine. 4 round tail lights and trunk hinges exposed.
Gas filler is in a different location. I have rear fender lips but not that large. Hood locks are in a different location. These could have been changed from original.
Dash board is different but once again, owner preference.
More pictures: Engine compartment, around steering shaft/throttle linkage area. Radiator. Fiberglass covering the front suspension. Door hinges and latches. Turn indicator at steering wheel.
I'm thinking Arntz not Butler.
Tom
Old 06-13-2013, 09:55 PM
decooney's Avatar
Engine compartment pics?
Duane
Old 06-14-2013, 04:11 AM
SunDude's Avatar
CMC, maybe...?
Old 06-14-2013, 05:08 AM
joyridin''s Avatar
The gas tank cap is inthe original Arntz position. Mine had it there originally but it was glassed over and moved to the rear fender.
Dash looks to have a glove box. No room behind my dash for a glove box. Maybe just a door?
Old 11-26-2024, 11:41 AM
I am trying to I.D. our cobra. I am told it is possibly an Arntz car. Though the frame on our Cobra has 4" square tubing, a mustang vin #, jaguar rear differential. I have no paperwork for the car. Mustang II front suspension and the lower control arm is a cast iron lower control arm with a strut rod. I believe the one major factor to help I.D. the car is the front lower control arms. Any help would greatly be appreciated.
Old 11-26-2024, 03:27 PM
mrmustang's Avatar
Gold Star Contributor
Perhaps start by creating a stand alone thread of your own instead of resurrecting one that died in 2013
eschaider likes this.
Old 12-10-2024, 05:05 AM
Thor maine's Avatar
Neutral
Artnz/Butler never had Mustang II front suspensiom!
Old 12-10-2024, 06:32 AM
DanEC's Avatar
I believe Arntz used 4”x3” frame rails.
ERA 782 Running
Old 12-10-2024, 08:14 AM
Cobra Make, Engine: Just a collection of parts right now...
Send a message via MSN to spl310
How about a Unique Motorcars Cobra? They used the MGB/Jaguar combo.
Old 12-18-2024, 01:31 AM
Question
Indeed they do! Do you have a factory serial number?
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
Old 12-21-2024, 09:58 AM
lal Naja's Avatar
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
If it's a Butler Racing Cobra you'll see a stamped serial number on the left front of the chassis. Here's a link to a photo of my Butler serial number.
https://photos.app.goo.gl/SHdKUiTGUbMzS5kGA
