Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Arntz/Butler Forum
Like Tree3Likes
  • 3 Post By EB847
Old 09-02-2016, 05:52 PM
Default My '79 Arntz at Mini-Nats 31 - Sears Point Raceway
https://youtu.be/i_r8278_-Hk
JBCOBRA, joyridin' and bjretired like this.
Old 09-02-2016, 08:25 PM
joyridin''s Avatar
Looks good! What engine do you have?
Old 09-06-2016, 04:47 PM
Thanks! 383 stroker built by Joe Boghosian
Old 10-10-2016, 11:24 PM
Excellent!
What front end / suspension mods are you running?
Old 10-13-2016, 03:01 PM
Thanks. MGB. There are some Butler upgrades on the rear at least that I know of. There was little documentation with the car when I bought it a couple years ago. There is very well balanced with no pronounced over or under steer. It has Wilwood calipers but I definitely need to figure out something as they overheated out there and got squishy toward the end of the run.
Old 10-13-2016, 04:25 PM
1795's Avatar
See if you can find a way to run some air ducts to the rotors, it will help cool them. Try to use the brakes as little as possible, quick hard braking and then off the brakes. You can also use downshifting/upshifting to transfer weight to the front wheels for turning. Another trick is to quickly taking your foot off the throttle, turn and then quickly accelerating to transfer weight to the front wheels and briefly slowing before turning during turns that do not require much braking. I would just caution you to attempt these techniques at slower speeds initially and only in corners with a lot of runoff in case you run into problems.
good luck
Old 10-13-2016, 05:10 PM
What brakes did the MGB front end Arntz come with? Is there a willwood upgrade available?
Old 10-13-2016, 06:28 PM
joyridin''s Avatar
I believe most of them came with GM rotors and Wilwood calipers. Are your cars set-up with twin master cylinders or a single cylinder? More than likely, it is the rear that are fading. Solid rotors tucked into the small space in the rear generate a lot of heat with nowhere to go. JH Engineering makes a kit for vented rear rotors, but it is not cheap by any means.
Old 10-13-2016, 10:07 PM
Mine has two masters. My brake mechanic is trying to get to them now as it appears there is a leak.
Old 10-27-2016, 04:27 PM
Good info. I will add ducts to the front. Would you happen to have a link to those rear rotors?
Old 10-27-2016, 07:11 PM
joyridin''s Avatar
PM sent.
