Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Arntz/Butler Forum
Old 04-18-2007, 05:05 PM
KZJim's Avatar
Default MGB Front suspension..
After looking at the MGB front setup on the Arntz car, there is no +/- camber adjustment other than changing the springs. Is there a source for diffrent springs?
People are more violently opposed to fur than
leather because it's safer to harass rich women
than motorcycle gangs.
I don't have the key to succuess, but I can pick a lock.
If it jams, force it. If it breaks, it needed replacing anyway.
"If you play with a thing long enough, you will surely break it..."
Old 04-18-2007, 11:06 PM
n6opv's Avatar
Default springs, etc.
Moss Motors has a good selection of springs, as well as most other items you might need for the front suspension.
http://www.mossmotors.com/Shop/ViewP...eIndexID=45242
Classic Conversions had camber adjustable lower control arms; not sure if he has any left in stock though. They lower the ride height about 1" by themselves and aren't recommended for use with shorter springs (too much neg. camber).
http://www.classicconversionseng.com/a-arms.htm
If everything is tight, bushings are good and the crossmember is mounted correctly, your caster and camber *should* be quite acceptable for most driving conditions without bad tire wear. Throw in a couple worn out parts though and all bets are off.
Jason
Old 04-19-2007, 08:16 AM
KZJim's Avatar
Jason
Thanks for the links... all the joints are good, it dosent look as if the suspension has seen any miles at all, if the parts came from a donor car it was rebuilt.
We are putting in a big block and want to be able to compensate for the extra weight and not have drastic +camber and tear up tires and stress the suspension any more than necessary.
Old 04-19-2007, 08:32 AM
KZJim,
Got my front springs from Ron Butler. The last number I had for him was 805-649-6000. He's not in the Cobra business any more, but might be able to help.
Old 04-19-2007, 11:55 PM
KZJim's Avatar
Thanks for the info!.. I'll give him a try...
Old 04-20-2007, 01:28 AM
WildBill3's Avatar
Default iv bought from here
VictoriaBritish Ltd.here in K.C.has alkinds of mg stuff.givem a try if you run out of avenues...WB
Old 04-20-2007, 08:27 AM
KZJim's Avatar
Victoria British.. thats the place I used to get my spitfire stuff from.... I couldnt remember the name.... thanks wildbill!
