| 29 |
10-05-2009, 05:25 PM
Vic
Garage Update # 3
Hi There,
While I was at the Nationals there has been progress, the weather was abit better in Victoria for a change
Side Fence line
Other Fence Line
Over View
Where's my backyard
Todays Job
At 6.30am today the steel arrived...there is a bit of rain around today so they might be held up.
HAPPY STIFFY
10-05-2009, 05:40 PM
NT
Stiffy, have you got an area of the slab (where hoist is going) that is the required thickness?
And if so are they going to set the floor mounting bolts in the concrete or are you going to dyna bolt it down?
Cruising in 5th
10-05-2009, 06:28 PM
Vic
Hoist
Boxhead,
the plan is for 3 x 4 posters (2 for storage and one on casters) the 2 poster will be set by dyna bolts. The slab is 150mm and 25MPA.
The inspector is going there today to look at the footings (then the slab company are DOING THERE STUFF). All is under control.
STIFFY
10-05-2009, 07:09 PM
NT
Glad to hear that was organised, would hate to see you try to drill holes for dynabolts only to drill through the slab
Cruising in 5th
10-05-2009, 07:13 PM
VIC
Originally Posted by stiffy
Boxhead,
STIFFY
Can I book a berth?
LoBelly
10-05-2009, 11:23 PM
Vic
Looks big enough to be a new home for cobra construction.
Starting into a new employment field Mr Stiffness??
slowy
10-06-2009, 01:14 AM
Vic
Brighton Rent
Lobelly,
Do you know how much rent is in Brighton???
Slowly,
With these hands, I dont think so TIM.....
No its just a garage, the house at the front is for washing and eating, well a few other things.
STIFFY
10-06-2009, 01:42 AM
Vic
Ok just the Tool man then!
slowy
10-12-2009, 05:24 PM
Vic
Progress Finally
10-12-2009, 07:13 PM
Vic
And if you want some extra special attention to quality, don't forget those green inducement packages too!!
The standard trades rate of pay - and now it seems Bathurst has made parity on this issue too!!
slowy
10-12-2009, 07:35 PM
Stiff,
Its form up the slab
Looking good - hope the rain stays away.
Switch to 40MPA and you'll be right - just may need an extra labourer or two
PCC (Peter Craig)
Keep the sun shining
10-12-2009, 11:27 PM
Vic
25mpa
PCC,
It is 25MPA X 150MM thick,
The 2 poster is in the middle of one of the footings therefore it will be in
500mm of concrete...... SAFE.....
STIFFY
10-12-2009, 11:44 PM
6" is fine - 2 layers of mesh?
PCC (Peter Craig)
10-13-2009, 01:10 AM
Vic
I prefer 8"
PCC,
One layer of F92 plus the stuff in the footings.
You seem to know a bit about concrete, are you in the game??
STIFFY
10-13-2009, 01:17 AM
Yep
Bit bigger pours though - 1,000 m3 not unusual
PCC (Peter Craig)
10-13-2009, 01:26 AM
Vic
Bl++dy Neighbours
PCC,
I had enough problems with my small garage (17m x 9m) the neighbours have been giving me HELL since I moved in,,,, or was it that I asked their daughter out
Either way they are pi$$ing me off.......
STIFFY
10-13-2009, 01:36 AM
Stiffy, keep the photos coming, they're great. What are your neighbors unhappy about? Looks good to me. I'd rather have your garage next to me than a couple of gum trees.
Regards.
Mando
10-13-2009, 03:18 AM
NSW
2 layers for slab on ground? Where would the tensile force on the top fibres come from? Usually that is used for suspended slabs and on ground designs with dodgy founding soil or funky loading. Residential garage slabs are usually only one layer. You must be used to the bigger stuff!
With F92 mesh and 150mm thick that is easily stong enough for your little daytona.. Unless you and Doug are planning on building a semi also?
10-13-2009, 05:13 AM
Stiff,
I did wonder why you had the temp fencing there
Zedn,
Its not unusual to include a 2nd layer of mesh in a 150mm or thicker slab especially if there's no added fibres in the concrete mix.
Yes I am used to the bigger stuff, but similar principles apply.
Stiff,
Good tidy job mate!
PCC (Peter Craig)
10-13-2009, 05:43 AM
NSW
plastic shrinkage cracking should be minimal in a 25mpa slab, especially in Melbourne. You are correct that it is not unusual to include a top layer of steel, but that is typical in suspended applications. Top steel is generally designed as per AS3600 where required in tensile zones that exist due to max moments in the top fibres near walls, columns, piles etc. It is also used sometimes to assist with tying stirrups for shear reinforcement and as you say control cracking due to early age, plastic cracks etc.
Sorry for getting technical, i am a civil engineer with a sub major in rehabilitation of concrete structures. I kind of get excited by concrete
