05-12-2010, 03:02 PM
heat sound insulation
has anyone had any experience with this stuff from ez cool insulation ?
http://www.lobucrod.com/
Like all this type of stuff it reads well, and there is a testimonial from a bloke in Adelaide as well so..........
Rog
05-12-2010, 03:08 PM
NSW
I dont know about that stuff, but i do know that the Dynamat is used by the majority of Hot rod and custom builders. That has to be some indication of its quality.
http://www.dynamat.com/
05-12-2010, 03:22 PM
Just about to put the Dynamat link on here as well, and I see that it's already done.
Ebay (Australia) has what seems to be some good deals on Dynamat..
http://shop.ebay.com.au/?_from=R40&_...All-Categories
I'm also about to get some for the new car...I'm thinking I might go for the BIG sheets of the stuff...seems you can get PLENTY for $400.
It's off to paint next week, so it's nearly time for the soundproofing to be done, prior to interior fitting.
Warren.
05-12-2010, 06:18 PM
I used an American product called Lizard Skin.
You spray it on in thin layers until it reaches the thickness of a credit card, and everything washes out in water.
You need to use a certain type of spray gun to apply it because it's so thick. Iv'e got the gun if you go down this road.
Regards.
Mando
05-13-2010, 03:39 AM
I used Dynamat and it is really cool.
There was an earlier/older thread:
Thermal Insulation
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
05-13-2010, 04:57 PM
Vic
Dynamat
Rog,
I have used Dynamat and a product called HEI Insulation. I picked it up from Summit with the Dynamat. I used 5 sheets of 1m x 1m stick on heat shield ( just enough ) and two large boxes of Dynamat. I went over board with both as the car was BLOODY HOT to drive. I also insulated under the tunnel with another HEI HI TEMP product ( 1700 DEG HEAT WITH 450 DEG SELF ADHESIVE GLUE ) very expensive ( $280 just to do the tunnel  ) the Dynamat and HEI product delivered was around $600 from memory. I also had the best heat resistant underlay installed AND carpet. I HPC coated the entire exhaust system.
Did it work????? As I type the car is gettting the A/C gassed and working correctly for my trip to Tassie next Month   .....
It certainly did help, dont know by how much but I can say I didn't leave any thing to chance. Its just a hot car to drive, probably similar to a GT40.
STIFFY
05-13-2010, 05:17 PM
dynamat gets my vote
05-13-2010, 08:28 PM
Vic
I'm assuming Dynamat is better for flat surfaces or is it fairly mouldable to curves?
If not what product would be good for curved and complex surfaces?
I too am contemplating cockpit floor insulation and also perhaps rear wall for both heat and noise.
slowy
05-13-2010, 11:11 PM
Any of these products ( Dynamat and similar ) are a fairly flexible thin sheet with a very sticky peel off backing.
You can use a small roller to press it into most shapes.
Warren.
05-14-2010, 12:24 AM
I have heard that on Harrisons that heat insulation is hardly needed. I sued it for sound deadening as well and also put sound insulation in the doors.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
05-14-2010, 02:31 AM
NSW
Litigation is also becoming popular in Australia !
05-14-2010, 01:57 PM
hahahahahahaah........
Hey thanks guys. Just keepin' the research going
Rog
05-14-2010, 05:14 PM
Rog
I used a product called Resomat available from Tru-fit Auto Carpets in Dandenong.
It comes in 3mm or 5mm thickness, 500 x 500mm self adhesive squares @ $12.00 each. Quite heavy, bituminous, aluminium sided for heat and sound deadening.
Really easy to apply, sticks fine after you use a good thinner type cleaner first.
Can't vouch for it yet as car's yet to run.
I have also HP coated extractors.
Greg
www.clubcobra.com/photopost/showphoto.php/photo/72438/ppuser/29710[/IMG]
05-14-2010, 05:27 PM
05-14-2010, 08:05 PM
Thanks Greg, I most likely will be in your area sometime next month, would like to call in and see how the project is progressing if possible
05-14-2010, 09:12 PM
Sure Roger, you're most welcome to drop in.
The car will probably be with the trimmer (if he doesn't put me off again) who is only a few km from me.
I'll PM you my email and ph #.
Just let me know when you're around
05-15-2010, 07:25 AM
WA
Speaking of sound deading, what do you all do in your wheel arches?
Between the sound and stones flicking up from the tyres how do you protect yourselves?
--JC
05-16-2010, 08:22 PM
VIC
I'm going to use neoprene (wetsuit material - Purple Pig had the best price), glued to the wheel arch with something like sikoflex. Then a thick coat of body schutz.
05-17-2010, 01:42 AM
body schutz !!???
Sambo does that mean it ' Does nothing ! '
as opposed to knowing nothing !   LOL
Rog
05-15-2010, 07:59 PM
I've got a few sheets of self adhesive rubber based sheet that the local auto paint supplier has. I've yet to try and stick it on.........looks like a fiddly job trying to get the curves right and gluing it up there.
Has anyone actually got any damage from stone strikes?
