Old 06-08-2010, 04:44 AM
Zedn's Avatar
Default Jag rear handbrake route?
Hi Guys,
I am installing my hand brake at the moment (jag rear). I have to mount the handle on the centre consul because there is no room on the right of the seat. The problem is that with the inboard brakes the cable has to come in from the side. Basically you end up with a very small cable that needs to loop out and back in the side.
I am using the Lokar handle and 'you cut to size' cable.
How i have it will work ok, but it is sort of jammed in there. I just thought i would ask how others have run the cable with inboard brakes. For those that arent familiar with the Jag set up, the two levers are pulled together to activate the brake meaning that the outside of the cable has to be able to move.
Any opinions are welcomed. Pics of other would be great.
Old 06-08-2010, 05:45 AM
stephen low's Avatar
Zedn
On your last picture where you have the cable leaving the brake lever and travelling forward, I looped the cable heading rearward first but essentially then looping 360 degrees to come out through the rear cockpit wall to the left side of the drivers seat.
The G Force, and I assume RMC, handbrake hangs off the driver's side of the tunnel, so the cable then just fed to the rear of the handbrake.
slowy
Old 06-08-2010, 06:16 AM
Zedn's Avatar
So the cable goes in a circle and back over itself? Any pics? I am trying to keep the cable from touching the body of the caliper in case the plastic melts.
It makes sense what you have done, how big is the loop though? I imagine it would have to be fairly big so the cable doesnt bind.
Old 06-08-2010, 04:38 PM
boss290cobra's Avatar
zedn i have the drb with jag rear and ialso have looped cable around diff housing but have swapped rhs brake to lhs and vise versa this was instucted by drb build manual in order to work correctly
damn these icv's :CRY
Old 06-08-2010, 04:47 PM
Zedn's Avatar
So does that mean yours activate by moving outwards instead of squeezing together? Any pics?
Old 06-08-2010, 05:33 PM
Zedn, you can also make a pivot bar from the first lever part way to the left lever with the outer cable pivoting on that bar.
That moves the fixed outer cable pivot more to the left and allows a larger radius on the cable.
Send me a PM with email and I'll send you a rough sketch.
Old 06-08-2010, 06:21 PM
Zedn's Avatar
Thanks Rebel,
I sent you a PM. I just spent two seconds drawing and came up with the answer. Thanks for making me think outside the box.
I am going to try two bars attached to the levers and meeting in the middle with a pin eg wide open scissors. My cable will then go straight to the middle and pull these bars to the front of the car. Cable can run straight then.
Your a Jenious!
Old 06-08-2010, 06:37 PM
email sent back Liam.
Cheers mate
Rate This Thread:
