Old 01-28-2011, 09:26 PM
renovationinnov's Avatar
merv
try the flake floor from your local "paint place" they have all different colours & surface finishes but make sure to read the instructions
we use this on factory floors & under house areas & just did a lab for soil testing
cost is dearer than jet dry floor paint but you get what you pay for
& they will warrant there product if you follow the directions & prep products / hope this helps
rob
rob's renovations& innovations [ chippy's ]
Old 01-28-2011, 09:59 PM
Merv and Sharon's Avatar
Thanks Rob. I was keen to get a plain colour if possible - so not sure if 'flake' means it has a random pattern. Can be hard to find small washers!
Will check it out.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 01-28-2011, 11:38 PM
merv
you can get all block colours[ the flake can be taylored to your requirements ] jaguar /rollsroyce use it for there workshop floors
flake is one colour & you add other colours to it if you want [ the base is usally white ] well thats what we use to give light reflect in dark areas
rob
Old 01-29-2011, 12:35 AM
Thanks Rob. This is the one: http://www.auzzieedges.com.au/concrete-coating.html
I guess I can do it myself? That is no contractor is needed?
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 01-29-2011, 02:55 AM
Krait's Avatar
Merv,
I used Jotun's Jotacote 605 on my shed floor.
Geoff
Old 01-29-2011, 03:26 AM
Looks good Geoff. Did you spray it?
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 01-29-2011, 04:49 AM
boxhead's Avatar
With a new slab, how long should you wait before painting and sealing the new slab?
I have come to realise I am beter off just to pay someone to assemble mine, I got onto a guy yesterday, He came out for a look today, and will start site prep tomorrow to pour footings.
Then he will be back in about 3 weeks to assemble shed, then straight after that I have concretors organised for the pour, then wait to seal.
Cruising in 5th
Old 01-29-2011, 04:57 AM
Krait's Avatar
Merv,
Nope, it was rolled on. I didn't do the work....was in Saudi paying for it
Boxhead,
Jotun like the slab to cure for a month, then it is acid etched. Once it's all clean and dry they apply the finish.
Geoff
Old 01-29-2011, 07:39 PM
Legless's Avatar
Cobra Make, Engine: DRB 302 Ford HO Block
Phil
This crowd have some pretty good products, I haven't done a garage floor with it just parking areas and driveway;
http://www.parchem.com.au
2 part sealer and tint will cost about $190 for 20lt. Some branches seem a bit dearer than others. I've found Riverstone pretty good and I think there's one in Penrith. Heed the safety warnings it can be nasty.
The product I used was this one, with a charcoal tint;
'The Coloured Concrete Sealer system is ideal for colouring and protecting plain concrete. It is a two part system; Part A the colour sealer clear base and Part B the colour tint. The Colour Tint (Part B) is added to the Colour Sealer Clear Base (Part A), and then applied using a roller or soft bristled broom'
They have other products as well, see the brochure.
cheers
Old 01-30-2011, 02:10 AM
Thanks guys. These guys have both the Swisstrax/similar tiles and the latest Citadel paints which are supposed to be 4 times tougher than epoxy ...
http://www.flexico.com.au/citadel-po...floor-coatings
and
for the tiles:
http://www.flexicoqld.com.au/floors
Dave - all seem to say at least a month for the concrete to fully sure before coating. However, with the heat you are having there ...
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 01-31-2011, 01:10 PM
Default Remote Oil Sender Unit LS Series
Hi People,
I need to add an engine oil cooler to the Daytona, like the driver it gets a bit HOT on the track.
I am running the 2009/2010 Camaro sump ( for extra ground clearance ) so I need an adaptor to suit, anyone done this already??
Part numbers would be great.....
STIFFY
Old 02-01-2011, 02:21 AM
I eventually went with these guys as they have a local supplier/applicator: http://www.concretecoloursystems.com...ing_system.php
Will be done on Monday-Tuesday at a very reasonable price including all preparation for 6 x 6 mtr area (< $1400)
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #33 (permalink)
Old 02-05-2011, 03:15 PM
AC-460's Avatar
I used Ameron Two Pac Epoxy for concrete......used a concrete grinder to run over the floor 100sqm this made the surface beautiful and smooth (if you want the top coat smooth youve got to get concrete smooth first) I then etched it with hydrocloric Acid 4-1 then pressure cleaned it .....I left it for a week then vacuumed before painting... The Ameron Epoxy could be driven on after about 3 days but took probably a month before it was rock hard
  #34 (permalink)
Old 02-06-2011, 05:38 PM
Having all that done today. Spent weekend cleaning the concrete and filling any holes and small cracks. House is quite new still. Will be interested to hear what the applicator says about drying time!
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #35 (permalink)
Old 02-07-2011, 07:13 PM
DaveW's Avatar
Merv,
How did the coating go, any pics and your prelim thoughts ?
DaveW
  #36 (permalink)
Old 02-07-2011, 07:51 PM
Happening as I type Dave. The Gloss coats are going over the flake/resin.
Will do in 24 hrs!
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #37 (permalink)
Old 02-09-2011, 12:30 AM
All done Dave. An impressive product. Has a 2 pack epoxy base, flake and then 2 pack urethane top coats. Very tough stuff and resistant to almost every fluid known to man. Can be driven on in 24 hrs but I will wait 48.
The cost was about $800 more than I could buy the materials for and included a diamond cut re-surfacing of the concrete, acid wash, etc. Was (only) 38 sqmtrs.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #38 (permalink)
Old 02-09-2011, 01:49 AM
leroy17's Avatar
Looks good Merv, and will be easy to keep clean as well.
I have garage floor envy.
Cheers.
  #39 (permalink)
Old 02-09-2011, 01:59 AM
I was going to eat dinner off it but the smell ... The guy that did it just got the contract for the new Jet Star terminal this week.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #40 (permalink)
Old 02-09-2011, 03:06 AM
hey merv
see you when to the 2pac flake floor [ what is the colours did you picked or was it the egg shell ]
you will love the ease of the floor clean ,wet or dry
did you get anti slip surface i hope warning drive in slowly if your tyres are wet
ROB
