  #41 (permalink)
Old 02-09-2011, 03:11 AM
Merv and Sharon's Avatar
Yeah Rob, kind of egg shell - was called Caramel Marble (Small) in http://www.concretecoloursystems.com...ing_system.php
Is also anti-slip. My wife reckons all i will need in there then is a bed ...
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #42 (permalink)
Old 02-09-2011, 04:32 PM
DaveW's Avatar
Wow, looks fantastic, my floor goes in around the 28th, probably have to leave for a while to cure before coating, did the contractor do the floor grind ? The concreter i'm using will use a helicopter float to smooth, but whether this is smooth enough for the coating, i'm assuming probably not. Being a urethane top coat, sounds like a relatively easy repair if damaged, (not to deep).
Looks great
  #43 (permalink)
Old 02-09-2011, 05:00 PM
Thanks Dave. My concrete was quite smooth and 5 years old. It has some fine cracks and a fair few paint marks and some oil spots. The floor contractor did a skim of the whole surface after attention to the cracks , then acid wash and so on. The concrete curing time may be relatively short, especially as the first coat is an epoxy and bonds with concrete well even if a bit damp, I am told. Other would know more.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #44 (permalink)
Old 02-11-2011, 03:28 AM
Krait's Avatar
Looking good Merv
Geoff
  #45 (permalink)
Old 06-01-2011, 07:03 AM
Philm's Avatar
Default Job Done
Finally painted the floor in the shed.
I used the PPG Amerloc Like Leigh and Stiffy.
Great stuff goes on really easy if you follow the steps.
I have learned that painting the floor with thongs (On My Feet) can be dangerous expecially when you step on a wet patch painted a few hours ago.
Started to get things organized.
Phil
  #46 (permalink)
Old 06-01-2011, 08:30 AM
Ralphy's Avatar
I had the wrong name, the product is called StoneHard. If you have money to burn this is it. Industrial quality materials.
Stonhard
  #47 (permalink)
Old 06-01-2011, 02:17 PM
Gav's Avatar
Gav Gav is offline
Looks great Phil, your feet should only be grey for the next hundred years or so
Powered by Cu
  #48 (permalink)
Old 06-01-2011, 04:25 PM
boxhead's Avatar
Looking really good there Phil.
Cruising in 5th
  #49 (permalink)
Old 06-01-2011, 06:03 PM
Chaplin's Avatar
I highly recommend U Coat It.
UCoat It Epoxy Floor Coating
It is a DIY system and they give you everything you need. I used it on my new slab and it went on easily and held up perfectly to rolling jacks, engine hoists, brake fluid, etc.
Replica is not a dirty word.
  #50 (permalink)
Old 06-01-2011, 07:41 PM
Tenrocca's Avatar
My sheds looking great Phil - thanks for getting it back in order for me.
  #51 (permalink)
Old 06-01-2011, 09:24 PM
Aussie Mike's Avatar
I saw the title of this thread and I thought it was about Andrew's paint job.
Mike Murphy
Melbourne Australia
  #52 (permalink)
Old 06-02-2011, 03:46 AM
Modena's Avatar
nice looking floor Phil, along with the contents of the shed
Ben in AU
