January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 06-18-2010, 07:08 PM
byroncobra's Avatar
Default Dash Pad for QLD Compliance
Fellas
Can anyone who's had Ray Cross engineer their car tell me what's the minimum acceptable for the dash crash pad?
It seems to be the case in all the pics posted here that digital cameras can't reproduce them
Thanks
Greg
Old 06-18-2010, 07:12 PM
Outwest34au's Avatar
Cobra Make, Engine: Evans kit, 6 litre, 6 speed, Jag F/R,
I know of one guy with a harrison kit that had Ray and used the blue foam camping matress material and then covered it with vinyl. It ended up about 20-25 mm thick. I am not sure if this was the correct thing to do but it passed. There is a spec somewhere regarding the density of the foam required. If you need to speak with him PM me and I will dig up a phone number.
Missed my Cobra budget by thaaaat much.
Ya get that on big jobs.
Old 06-18-2010, 07:22 PM
Merv and Sharon's Avatar
Greg I used Warwick's fiberglass piece with thick foam and black vinly covering. I can lend it to u if u can't get one
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 06-18-2010, 07:57 PM
byroncobra's Avatar
Thanks Fellas
Merv, the borrowing option sounds good thanks! One less job to muck about with. Depending on how long the trimmer has my car, I may need it in a month or so (I hope)
Given the 3 hour drive between us, if you're heading south let me know and maybe i can sort a drop off in Bris or GC
Old 06-18-2010, 09:51 PM
Will do Greg. I will be down for a short trip to Bris next Monday morning and could leave it in the city but I might be easier to post it if you're not coming up?
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 06-18-2010, 11:13 PM
byroncobra's Avatar
Merv
I've PM'd you
Thanks
Old 06-19-2010, 01:41 AM
WKB's Avatar
WKB WKB is offline
Cobra Make, Engine: Harrison Cobra, SC540 Roadster
I don't know if this will help. The check list that I recieved from Ray states "CRASH PAD FITTED TO DASH – PADDED HI-DENSITY FOAM."
Warren
Old 06-19-2010, 02:00 AM
Ray liked mine! PM back Greg.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 06-19-2010, 02:37 AM
victor's Avatar
Cobra Make, Engine: DRB "Rough as Guts"
Warren
Any dangerous or sharp projections must be removed. These include edges that are exposed as a result of cutting and removal of body sections. All edges that vehicle occupants may contact must have a radius of not less than 5mm and a minimum thickness of 5mm of high density energy absorbing foam or similar material bonded to the surface and suitably trimmed.
Hope this helps...Found in Regs
XBorderMexican
