Old 07-19-2010, 04:39 AM
Cobra Make, Engine: Harrison #102 Ford 5l Fuel Injected AU 2
Cool Starter Motor
Looking for a price guide Starter for Ford V8 Windsor 5L Ex Au Falcon Ute 02/03 Build.
Have been quoted by local Bosch service centre Sunshine Coast $ 260--00
as old unit too expensive to clean and service seems a bit rich.
Any thoughts??
Old 07-19-2010, 05:42 AM
Merv and Sharon's Avatar
Hi Trevor! Well done. I guess you know these guys but they do have some good starters: http://www.castleauto.com.au/hs_dbas...FsbHNlYXJjaA==
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 07-20-2010, 02:24 AM
I would go for one of the gear reduction types Trevor. The Castle ones are more expensive but better quality. I fitted one over the last few days and the old 'clapper' is on the shelf!
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 07-21-2010, 07:27 PM
stephen low's Avatar
Trevor
The starter units aren't cheap.
I found a fellow down here in Victoria off ebay who could supply me just the solenoid unit very cheaply, when I got overkeen tightening up my electrical connections in original build.
I snapped off the contact and was sure I'd have to buy a whole starter. Recall my initial research into those prices was frighteneing but am also pretty sure looking at the same fellow's starter prices by comparison he was a whole lot cheaper.
Fairly sure this ad refers to this same fellow.
http://cgi.ebay.com.au/Brand-New-Sta...item415093ce87
Mind you on ebay the prices are all over the shop. I'm assuming there may be particular features with one starter over another.
Good luck.
slowy
Old 07-21-2010, 07:48 PM
SoTxButler's Avatar
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
Trevor,
Get yourself a gear-reduction starter if you need to replace your starter. They are available anywhere from 3:1, 4:1, 4.4:1 and even 5:1. The gear-reduction ones are smaller, and will spin higher compression motors more easily, especially when the motor is hot. The higher the compression, the more gear you need.
They should generally last a lifetime. I like the RobbMc starter, a 5:1 gear. They are expensive, (robbmcperformance.com) but living in a hot climate and running 11:1 compression, I want a strong starter.
Good Luck
Russ
Old 07-22-2010, 12:22 AM
Wazza's Avatar
Originally Posted by SoTxButler View Post
Trevor,
Good Luck
I'm sure I've mentioned this before...
But...
Your Gallery makes me SICK !!!!
But in a very good way...
Bloody beautiful gear,
Warren.
Old 08-24-2010, 05:02 PM
Thanks for your thoughts I chickened & bought the new as was oem.
regards
Trevor w
Old 08-24-2010, 11:26 PM
Cobra Make, Engine: King Cobra, QLD - 347 windsor
Thanks WAZZA,
No I too have a gallery that I despise. Bloody Hell there is some nice looking gear on that car.
