Old 09-05-2010, 11:23 PM
Cobra Make, Engine: DE Type Cobra Ford Windsor 302, 5lt fuel injected. Ford front and rear. 9" lsd.
Default Wiper bezels mounting measurements?
I am mounting a Lucas 2 wiper system and before I go drilling holes in the fiberglass I was wondering if anyone had some suggested measurements they could supply. Either from the centre of the body or from either side of the windscreen uprights.
Cheers Damo :
Old 09-05-2010, 11:43 PM
boxhead's Avatar
Damo, I would try to make contact with Hogster, I think from memory he has a DE Type aswell.
On another note, I will be over your way early October with my Cobra, can you start praying for the rain to stop?
Cruising in 5th
Old 09-06-2010, 12:17 AM
Damn rain! its not supposed to be raining now. Do pop in if you are in Cairns
come and see us at Cairns Airport Rentacar and Cairns Older Car Hire, You can have a look at the progress we ve made on the Cobra i'd say we are over half way.
Cheers Damo
Old 09-08-2010, 07:05 PM
Cobra Make, Engine: King Cobra, QLD - 347 windsor
Have sent you a PM the same but I have found and uploaded the instructions I have to my gallery. Triple wiper setup though.
Hogster
Old 10-05-2010, 05:56 PM
For anyone else fitting a 2 blade wiper set up, the lucas motor i had came with a 90 degree gear. The driver side wheel box would have to be mounted too far to the right hand side that there is not enough room under the dash to mount the motor.
Make sure you get the 130 degree gear to enable mounting the wheel boxes closer to the centre of the dash ( more room there for the motor).
I hope this helps save someone some time.
Damo
Old 10-05-2010, 06:49 PM
mickmate's Avatar
Wipers are 19 1/2" apart on the centreline of the car. The holes are about 3 1/2-3 3/4" back from the edge of the bonnet opening. Holes are 5/8" diameter and drilled at a 40 deg angle to the horizontal. Put the motor right up the front of the footbox if you want room for fresh air flapper valves.
mickmate
http://www.actoncustom.com/
Old 10-05-2010, 07:16 PM
Damo
For those wanting to change the "stroke" of their wiper motor .. look here for some info and hints.
http://www.erareplicas.com/427man/wiper/index.htm
