10-08-2010, 07:22 PM
NSW
Cobra Make, Engine: Classic Revival 3506
side pipes
Well after my search has turned up as a dud and not able to find anyone in Australia to make me pipes ,its back to the old undercar exhaust.
And to be truely honest i think the sidepipes are too bloody loud and give you a head ache after a while.
Thanks again Paul
10-09-2010, 12:40 AM
au
Cobra Make, Engine: ROBNELL
Thanks again Paul
Yeah.........
And V8's are way too fast.......
10-09-2010, 01:21 AM
Vic
Cobra Make, Engine: Classic Revival.
May have a pair up in the roof if interested ???
Dale
10-09-2010, 01:53 AM
NT
Paul, I love my side pipe noise, under load or heavy acceleration they are nice and meaty.
But when cruising (and I am doing plenty of that lately) I have more tyre noise than pipe noise.
Cruising in 5th
10-09-2010, 03:36 AM
qld
ptrefry i've tryed afew places & they custom make them at a cost
i,m trying to get a set so i can run them [side pipes] then cut back under to the rear
as per adr rules they have to exit to the rear
10-09-2010, 04:49 AM
NSW
Any half decent fabrication place should be able to make them for you. Just look up local stainless fabricators and take them a picture of what you want. At the end of the day its just stainless pipe and mandrel bends. You would probably get a better price from them instead of a car parts supplier.
10-09-2010, 05:19 AM
Q
Wow - it took you only 5 days after asking the question to give up??? As others have said, talk to a local exhaust fabricator. I could name half a dozen places within an hour drive from me who could make a beautiful set of pipes, customised to your desired noise level...
Craig
10-09-2010, 09:05 PM
NSW
Too loud Too old
Thanks again Paul
You sook
Aussie Mike might make you a set or as Craig says any good exhaust place worth their salt would make you whatever you want. Mine are just 100mm stainless pipe with 4 100mm stainless Mandrel bends welded on with a triflow baffle setup inside. Around $600 from memory.
Brett
289 FIA Cobras RULE!
10-09-2010, 09:33 PM
NSW
Originally Posted by BJ's Snake
You sook
Brett
Can you explain what a triflow baffle set up is please ?
10-09-2010, 09:59 PM
NSW
Paul already has side pipes - he is after a new set that are more authentic looking.
Personally I think the ones on it now look fine!
Ben
10-10-2010, 08:48 AM
Ne.
If you're interested, I've shipped these to Germany, England ect.
They are not quiet, but a cobra is supposed to be. lol
Kevin
10-10-2010, 04:27 PM
NSW
sidepipes
thanks they are very nice indeed but not quite what i was after
10-10-2010, 04:44 PM
Ne.
I can check into a real quiet muffler if you wish. If not, that's ok.
Kevin
10-13-2010, 09:55 PM
nsw
Cobra Make, Engine: DAX 351 windsor
Kevin, What kind of money are you asking for a set of your pipes, canyou make them without the finish, wouldn't want to damage them when trying to fit them, thanks.
10-14-2010, 01:50 AM
NSW
Googled it and found a design patent description. It looks a bit constrictive...what's others opinion ?
10-14-2010, 05:54 AM
Ne.
$2,100 for the entire kit. All you need is the 4-hole primary flange to match up to your headers. Too many variables with your engine, body cut outs ect.
When your fitting your side pipes, just wrap them in a towel and blue painters tape. If you do get a scratch, stainless is very easy to polish them out.
Here's our muffler. Point the louvers away from the engine for better flow, or towards the engine for a bit less noise. Look how restrictive one of the manufactures muffler's are.
4-HOLE FLANGE-
OURS-
THEIRS-
Kevin
10-14-2010, 01:56 PM
nsw
Thanks Kevin i'll keep them in mind, I know which way i'd point the louvers.
