  #81 (permalink)
Old 06-05-2011, 02:24 AM
LoBelly's Avatar
just turning several shades greener right now...
looks like you're going to be well placed to save all those old chryslers
a review of the gear you got and how you feel it stacks up would be good once you've had a bit of a play
LB
  #82 (permalink)
Old 06-05-2011, 04:26 AM
you win...........
  #83 (permalink)
Old 06-05-2011, 06:26 AM
boxhead's Avatar
It cant be too hard to make an alloy Le Mans top could it???????
Cruising in 5th
  #84 (permalink)
Old 08-07-2011, 07:24 AM
boxhead's Avatar
Well, weekends have been crazy busy for the past couple of months (I have been home 3 weekends since start of June).
Spent today out there running hibay lights and power points (doubles every 4 metres).
Took a quick snap.
Then late this arvo I also started to remove sheeting where sheds will join, measured up required steel and will also grab that tomorrow.
I have fitted a socket plug to hibays and will be digging holes tomorrow after work to cement the poles in for shed joint.
Hope to have electrical work completed by friday night so I can get sparky in to connect on Saturday morning.
Cruising in 5th
  #85 (permalink)
Old 08-07-2011, 02:57 PM
Merv and Sharon's Avatar
Gees Dave you may need your own power station for those? Do you have solar out there? Would seem the ideal location.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #86 (permalink)
Old 08-07-2011, 08:09 PM
boxhead's Avatar
Have looked at Solar, and will be doing it (shed build got in the way).
Lights are probably over done, but I hate working in the dark.
In all honesty it will probably be bright enough with just the centre 2 lights on.
They are wired in 3 seperate circuits along length of shed, so can only turn on the ones I need.
With the roller doors down, there is enough light comming in through the clear panels in the roof, I think something to do with all the insulation on the walls, reflects light everywhere.
Cruising in 5th
  #87 (permalink)
Old 08-08-2011, 09:56 PM
boxhead's Avatar
Uscrewed all the sheeting between two sheds last night, dug some holes and cut the uprights to length.
I will be cementing the poles in tonight.
I also had 1 row of lights on last night while working, Fark it was bright
Cruising in 5th
  #88 (permalink)
Old 08-14-2011, 11:15 PM
boxhead's Avatar
Managed a little more progress over the weekend (had to do the right thing with my beter half on Saturday so lost most of the day)
I made a new end "A" frame for roof truss, I have ordered more "C" section for the last of the rafters.
Once they are in place I can screw the roof sheeting in place with flashing and centre cap.
Here is the view from inside new shed, looking to old shed, the centre upright will come out once the 2 extra ones are secured to the ground.
Cruising in 5th
  #89 (permalink)
Old 08-15-2011, 04:38 AM
Modena's Avatar
Good Dave. I think you need to clean up that old shed
my mum has that same step ladder.
Ben in AU
  #90 (permalink)
Old 08-20-2011, 07:02 AM
boxhead's Avatar
Well, I now have power in the shed and all is working.
Getting a paid job out of the way then it is Cobra time.
And the clean up has begun
Cruising in 5th
  #91 (permalink)
Old 08-21-2011, 06:21 PM
boxhead's Avatar
Time to replace shockies and fit some pusher fans.
Cruising in 5th
  #92 (permalink)
Old 12-14-2011, 06:13 PM
boxhead's Avatar
Now its a Blokes shed.
Cruising in 5th
  #93 (permalink)
Old 12-14-2011, 09:46 PM
That's a brazen Box............putting a picture up of your Missus like that
Rog 246
Harrison #100
  #94 (permalink)
Old 12-14-2011, 10:20 PM
boxhead's Avatar
LOL, she is probably young enough to be my daughter.
Cruising in 5th
  #95 (permalink)
Old 12-18-2011, 03:42 AM
boxhead's Avatar
I picked up a lathe on Saturday, she is an old one but good enough for the sort of uses I will have for it.
Cost me a carton of Rum & Cola, and I also bought a carton of XXXX Gold for teh boys in the workshop.
Its a Colchester Master model, 6.5 inch, I think it is a "series one" model that dates it to 1955/1969.
A few companies in the UK list all parts are available.
Once I find the serial number I should be able to figure out a little more about it.
3 phase and was working when moved outside.
Cruising in 5th
  #96 (permalink)
Old 12-24-2011, 08:39 PM
boxhead's Avatar
I had a name change yesterday, I became known as Davidicus Boxyopolous.
Now please excuse the mess, but I have just moved stuff "out of the way" to get the job done.
The time had come to concrete the "gap" between old and new sheds, I also had to remove the centre support from old shed (had put two extras on teh sides).
Then clean up the area to concrete, add plastic and reo mesh, also placed the bolts in the ground to secure the new supports.
Then I started mixing and pouring concrete.
Then I went over it with a broom about 4 hours later, pobably should hae waited another hour or so.
The finish is not as nice as the new shed, but beter than the old shed.
It was a 5.30am start, and all was done and cleaned up by 10am.
there was 280 shovel loads of agg mix and 260kg of cement powder into that floor.
And it was warm, after a shower I ducked into town.
Cruising in 5th
  #97 (permalink)
Old 12-26-2011, 04:40 PM
Thumbs up
Dave I didn't see any date or hand prints in the 'crete !?!!
Are you sure you did it ?
Rog 246
Harrison #100
  #98 (permalink)
Old 12-26-2011, 05:16 PM
boxhead's Avatar
No names or dates, just DNA from all the sweat.
Cruising in 5th
  #99 (permalink)
Old 01-02-2012, 04:50 PM
boxhead's Avatar
A little more organising and cleaning up happened.
Some shelving for getting everyting off the floor.
Half a dozen of these scattered around the workshop.
And you can see the mess in the background of the picture, that was all tossed there during shed build and moving walls etc.
Well, it was time to clean that up, now that there was shelving storage, tossed some out, kept some and will sell some other crap off.
Cleaning it would also give me access to the swampy again, and give me room to pull the K frame and suspension from the donor car for George the Goon.
Thats as far as I got before a mate arrived with a 6 pack of Boags.
Cruising in 5th
  #100 (permalink)
Old 01-02-2012, 09:53 PM
renovationinnov's Avatar
so dave what did you do for the rest of the day
except drink
rob
