Old 04-03-2011, 04:39 AM
guye's Avatar
Default Shed Question - size?
Now I know you are all going to say that size DOES matter, but unfortunately I am limited at home (I know - snicker snicker....).
She-who-shall-be-obeyed suggested today, as I was staking boundaries, that I might as well bring the side wall of the impending shed out a bit into her garden to maximise the internal room! What a woman!
That will give me a shed about 4m wide. The length is fixed at 5.4m.
As you can see from the rough 3Ds below, the roll-a-door is NOT at the end but on the side. The roll-a-door is 2.5m wide.
I marked out the area on the road today, and I reckon I can get my car in (with a million-point manoeuvre) but the Cobra will be about 1m shorter, with a much shorter wheel base as well.
My main question is: what sort of turning circle do your cars have? Any one actually have a stat on this?
Do you think I will have enough space with working room, etc?
Any other comments or thoughts?
Guy
Old 04-03-2011, 04:43 AM
Modena's Avatar
I will have a similar problem;
and will use go-jacks;
http://www.gotools.com.au/GoJack.htm
http://www.revolutionracegear.com.au...php?PCID=10540
Ben in AU
Old 04-03-2011, 07:32 AM
jcraigau's Avatar
Boom, problem solvered!
http://www.3dparking.com.au/turntables.htm
http://www.turntables.com.au/Pages/P...urntables.aspx
Old 04-03-2011, 03:07 PM
Modena's Avatar
I looked into a turntable - price was upwards of 20K
Ben in AU
Old 04-03-2011, 03:15 PM
I'm building mine on a rotisserie because i have limited area (was gunna say size-but didn't want to go there on this site ) and its working out real well as it allows me to move it around by myself very easily and I can roll it over etc-works a treat and only cost $1100-
Beats crawling around on the ground too I can tell you! Its nice to be able to go Hmm might fix some fuel lines today and do it sitting on a stool!!
Rog
Rog 246
Harrison #100
Old 04-03-2011, 07:51 PM
guye's Avatar
Rog
Nice Rog - but it is not April 1.
Guy
Old 04-03-2011, 07:58 PM
Krait's Avatar
Guy,
Don't think it was a joke.
Geoff
Old 04-03-2011, 08:02 PM
guye's Avatar
Originally Posted by Krait View Post
Guy,
Cool! I had seen those but thought it was just good for the body work - not the whole chassis, etc!
Unjoke assigned to Rog!
Guy
Old 04-03-2011, 04:19 PM
boxhead's Avatar
My only question is, what are you going to do when it is finished?
The last thing you will want to do is move it around on quickjacks every time you want to take it out.
Any reason why no roller door infront of it?
Also depending on what kit you get, could help in the space bit.
For the first 3 years of my build I was in a very small shed (could not have both doors open), the CR has a seperate chassis/body, I seperated the 2, sat the body on a jig with wheels, this lived in the backyard while I was working on the chassis, then swapped the 2 around when doing body stuff.
But any shed is beter than none.
Oh, and at 5.4 metres long, you may not have enough room to jack the car up?
Cruising in 5th
Old 04-03-2011, 08:00 PM
guye's Avatar
I know, did think about this. Probably, given I expect that to be at least 3 years away, I wil either move by then OR put my daily driver on the street!
To answer your question though, check out big mother f@#$ing gum tree where I would LIKE to put the door (on the left behind the letter box)! My council has all the trees named so planning and removal is a real pain (this one is called Kevin).
Length of Cobras are about 3.8-4.0 metres, according to my research. I do not intend to place any benches or cupboards at the ends, only the sides of the shed, so I should have at least 1.5m to crank the jack. Obviously only from one end though (have to back it all the way tot he other wall for that much space).
I kind of figured I would have to jack from the sides only - awkward I know but possible ya think?
Guy
Old 04-03-2011, 06:05 PM
Move would be my suggestion.
Also people have way too much time on their hands to be drawing 3d cad layouts of their garages.....
Old 04-03-2011, 08:29 PM
boxhead's Avatar
Yep, wider (wide as possable) roller door, idealy I would say no roller door, but I can see if you close in side of carport, drivers door on the (Pathfinder?) may be hard to get open far enough.
Cruising in 5th
Old 04-03-2011, 08:58 PM
A couple of options
Put a contract out on Kevin, it's amazing what a few lt of round up will do.
Or raise the roof of the garage and extend it forward a mt or so, put in a hoist to stack the cars when built, a hoist is also a great help when building the car. Turn the proposed side part in to a workshop.
Old 04-03-2011, 09:18 PM
Gav's Avatar
Gav Gav is offline
Why not remove the common wall between the two sheds?
You could then just drive in through the existing carport.
Powered by Cu
Old 04-03-2011, 11:12 PM
REPTYL's Avatar
Cut down the tree, pay the fine, and put the door right where you want it.
Old 04-03-2011, 11:39 PM
OZCOBRA's Avatar
....and bury it under 400 tonne of landfill!!!.......any wonder of things one could have put in there!!
Old 04-03-2011, 11:10 PM
boxhead's Avatar
That is what I was thinking Gav, but it is not secured then, and I dont think there is enough room to close in the current carport and add a roller door to the front of it.
Cruising in 5th
Old 04-04-2011, 12:05 AM
boxhead's Avatar
I vote that Kevin stays, but he is in a bad place.
Cruising in 5th
Old 04-04-2011, 02:00 AM
Jethrow's Avatar
Cobra Make, Engine: FFR Mk4 Roadster, LS3, TR6060, 8 3/4"
You need Go Jacks
These will help in moving car about.
Tim
FFR Mk4 Roadster
HSV Clubsport R8
Old 04-04-2011, 05:03 AM
guye's Avatar
Thanks for all the help & advice guys!
a) I can't close in the existing carport at all (council regs), and anyway Boxhead is right - not enough room to open the car doors.
b) I actually, begrudgingly, am rather fond of Kevin, so can't put out a contract on him
c) A wider roller door is probably the best idea. I have, however, a supporting post in the middle which I would have to move - structural challenge (but not impossible). I've decided therefore to actually go for the 2.5m door and probably employ GoJacks. Then I'll review things in a few years when the car is built - perhaps getting a sider door then will be the best option.
d) Most importantly, I already have a bar fridge for the shed, PLUS and old TV to watch the GPs (Moto and F1)!
Guy
