questions
- » Blogs
- » Image Gallery
million posts!
| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
04-12-2011, 04:25 PM
AUS
My wifes Contemporary with 351 Cleveland, top loader & Jag running gear weighs 1120kg.
It's fully painted and trimmed with all accessories. That's with 40lt fuel and tonneau cover, car cover, towels and I'm sure there is a girlie emergency kit in there somewhere.
I forgot to write down the front to rear weight bias, but it was only slightly heavier in the front.
04-15-2011, 03:47 AM
QLD
Had the Cobra corner weighed today. Was carrying less fuel, maybe 15 litres in total.
LF/RR cross weight is not flash, RR is heavy. No, the driver was not in the car
Didn't do any adjustments at this stage as we're looking to get some more castor first.
Geoff
05-09-2011, 06:00 PM
Vic
Krait what do you put the LF/RR issue down too??...10kgs seems a lot without you in!!
05-09-2011, 07:09 PM
QLD
Originally Posted by OZCOBRA
Krait what do you put the LR/RR issue down too??...21kgs seems a lot without you in!!
Fuel system,Battery..Cockpit????
Over the last week of so there's been a bit of work done to the front end to increase caster. Once that was done the car was corner weighted again and the spring perches adjusted. Had about half a tank of fuel this time. Battery location has always been behind the radiator.
Result was LF 270 RF 301
LR 311.5 RR 345.5
LR/RF Cross 612.5
RR/LF Cross 615.5
Total 1231kg inc 91kg driver ballast
3kg is a much better result.
Steers a lot better now too.
Also used the opportunity to install the Corvette sump that I've had sitting in my Saudi apartment for over a year. The original sump had scrape marks where it occasionally hits the edge of my driveway.
Geoff
Reason: Added info
04-15-2011, 03:53 PM
NT
I do like a white Cobra.
Cruising in 5th
04-15-2011, 04:20 PM
QLD
Thanks. That's the third positive comment in less than 24 hours.
Geoff
Reason: typo
05-09-2011, 05:20 AM
Q
Just saw this surprising weight...
Autokraft alloy bodied Cobra. 3055lb!!!
Craig
05-09-2011, 05:36 AM
QLD
That's not as heavy as Phil Mizzi's .....
Earlier in this thread Phil was saying his weighed 1,400 kg....
That's about 3,080 pounds !!
Pretty heavy Cobras.....all that H.P. and Bling hey Phil ??
Warren.
05-09-2011, 05:53 AM
Q
Seems crazy that my Mercury Comet (with a boot big enough to fit the entire cast of Sopranos), with a full tank of fuel, iron small block with iron heads, iron intake and cast headers weighs 2860 pounds!
Craig
05-09-2011, 02:30 PM
Qld
Weight loss
I am working on the weight issue my car has.
1. New aluminum 8.8 inch diff going in.
2. Au falcon rear control arms replaced with chromoly tube arms.
3. SFI scattershield replaced with Lighter quicktme belhousing.
4. Advan Light weight racing rims replacing the Billet rims.
This should reduce the unsprung weight by half and the overall weight significantly.
I am not sure how much fuel the car had in it when it was weighed so maybe if it had 50kgs of fuel, I will only run with enough fuel for the session next time.
Also the driver can drop about 15kgs as well!!!!
Phil
05-09-2011, 05:31 PM
Vic
Phil
...Only 15kgs!!!!!!!!!!!!!!!!
05-09-2011, 09:38 PM
VIC
Hi Geoff, I'm curious to hear why you went for more castor and how it was done. It looks from the above photo that you have replaced the Z arms with adjustable items and bent/pressed the upper A arms?
05-10-2011, 02:47 AM
QLD
Hi Paul,
Being back in Oz for a few months has allowed me to do a fair bit of driving in the Cobra, didn't get home at all last year and the poor thing sat in the shed  I felt that the car was a bit darty on the road and wasn't entirely happy with the self centring of the steering. Anyway after some consultation decided to add caster and get the balance sorted.
Simply installing the adjustable radius rods added considerable caster but pulled the wheel too far forward in the arch. In the rally cars I used to play with we used adjustable radius rods and adjustable tops on the MacPherson struts to achieve camber/caster. So to move the upright aft new top wishbones were fabricated with offset built in.
On the drive home the car seemed more planted. Unfortunately the speedo lights and the temp gauge played up so I've had the dash partly pulled apart hence unable to go out for a drive since. Hopefully Thursday the missus and I will head down the coast for lunch.
Geoff
05-10-2011, 01:58 PM
QLD
Geoff, your adj. radius rods ? Did you make them up or are they an off the shelf item ?
Rog
Rog 246
Harrison #100
05-10-2011, 03:52 PM
QLD
Hi Rog,
They're a Whiteline product, W82567. Fairly beefy for our use but easier than fabricating an alternative.
Geoff
05-10-2011, 09:45 PM
QLD
I used their upper arms on my rear suspension. Nice products.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
05-10-2011, 10:38 PM
QLD
Thanks Geoff, reckon I might just get me a pair them
Rog
Rog 246
Harrison #100
05-11-2011, 12:18 AM
QLD
No worries Rog, just remember that adding too much caster will result in the wheel not being centred in the wheel arch.
Geoff
05-11-2011, 01:13 AM
QLD
Thanks Geoff, I was a rubber grub ( worked in tyre industry) for quite a while, so am more than aware what it all does. thanks again
Rog 246
Harrison #100
11-30-2011, 07:58 PM
Yeah Harrisons are usually 50/50 with an iron block V8 up front.... Alloy engines are obviously lighter..... My DRB is the same, 1285kg with me in it and half a tank of fuel, 642 front and rear... No alloy engine..
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
