LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 04-23-2011, 03:50 PM
07cob's Avatar
Default Soft Top
All
Well, it has taken longer than building my car in the first place, but I am finally ready to get the Soft Top made. Here are some progress photos of the frame and a mock up with a sheet to check the overall shape. The canvas will be quite a lot heavier than the sheet so hopefully won't have such sharp corners - something I am trying to avoid.
I am not 100% sure about the height - I will do another mock up later today and might lower the rear and centre bows a little.
Bend in Al channel for header bow
Frame
Mock ups
Geof
Old 04-23-2011, 04:25 PM
Zedn's Avatar
Looks great,
How did you bend the channel?
Old 04-23-2011, 04:47 PM
sambo's Avatar
Looks good Geof. What are the bows made from and how do you get the nice bends/radii?
Old 04-23-2011, 05:49 PM
07cob's Avatar
Default Soft Top
Liam
I made up a bending jig as shown in the photo below. It is a bit agricultural but it does the trick. The Al was annealed then it is as simple as rolling it around the corner (with a degree of brute force and ignorance). There is some distortion but no cracking. I just filed down the excess material to give a reasonable finish.
Paul
Bows are just 10mm mild steel. I started this as a *prototype* with the intention of going to stainless once complete. Given that it took so long to get this far, I reckon I will be happy with this for a while now. All the radii are bent by hand and eye. Once I cut the bows in half, I adjusted them to ensure some degree of symmetry.
Geof
Old 04-23-2011, 06:04 PM
renovationinnov's Avatar
just got to love a ""rag top "" all puns intended
top job , nice jig for radial bends keep us posted
Old 04-23-2011, 06:56 PM
Merv and Sharon's Avatar
Neat jig Geof! I am sure that you went through this earlier thread Hoods and Tonneau covers
The shape of the top is a tricky thing. I did not want a pronounced bend up in the middle
To do so I had to reduce the height of my roll bar (it was far too high anyway) and play around with the height of the bows a bit. I also wanted a bit of a slope at the back. The old sheet trick is a good way to test the options out!
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 04-23-2011, 11:37 PM
Err so Geof, when are you taking orders for these ?
Rog
Rog 246
Harrison #100
Old 04-24-2011, 12:52 AM
07cob's Avatar
Merv
This is actually one of the things I was trying to achieve. I want the top to resemble the shape of a hardtop with the curve up off the screen then curve all the way back to the deck. I still reckon I could come down a bit - I will have to test this out later - didn't get a chance today.
I agree! So much so in fact, I considered taking the top back over the boot to create a Le Mans style soft top with zippers beside the boot for access. Not quite brave enough to give that a go though.
Geof
Old 04-24-2011, 12:55 AM
07cob's Avatar
Rog
Rog
It took me almost two years to get this far, .......
Geof
Old 04-24-2011, 06:03 AM
I am ALMOST ready to do the hard top with Steve, for the Harrison. The mould is now ready I believe. It is fairly flat too. I think we had some photos earlier on it.
I found that with the soft top I used it more in summer for heat (in QLD), whereas the rain, well it just came in the sides. Wind flap was not a problem with the shape I have. Fitting windows to the soft top is hard and resembles the old MGA/clubman design. The hardtop can take a fixed window.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 04-24-2011, 06:59 AM
jcraigau's Avatar
I was thinking of getting a second set of doors done with glass in them for winter time.
This came about after the wife won't ride around in her MX5 without the windows up (something about the hair?). Roof off is no problem.
Not sure about having them workable with winders or just set in place with a slider assembly.
Old 04-24-2011, 03:52 PM
Originally Posted by 07cob View Post
Rog
Geof
So ...............ypu're taking order well in advance then !?!
Rog
Rog 246
Harrison #100
Old 04-24-2011, 04:24 PM
Outwest34au's Avatar
Good stuff, the shape does look good.
For those that missed it here is a good article on bending channel with view to making window frames. Home-made Side Curtains for Lemans Top – “How To”.
Ya get that on big jobs.
Old 04-24-2011, 08:56 PM
Very good article. Have filed that one away!
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 04-25-2011, 02:54 PM
07cob's Avatar
Default Softening Aluminium
Great tips in this write up. The Lotus site quoted (LocostUSA.com • View topic - Trouble Bending Aluminum for Windshield. Help) is where I got the idea for the jig.
The tip about using a Sharpie as a temperature indicator for annealing is also a good one.
I used soap for this. Rub the soap on the top three faces of the channel the heat from below. I used a LPG torch. The soap will turn brown then black. Afther that the aluminium will start to melt - not good!! Same as the sharpie method - stop heating as the soap goes black. This is the discoloration on the channel that can be seen in the photo above.
Colour chaning crayons can also be used if a more exact temperature is required.
The only downside to this is that unlike other metals, there is apparently no way to re harden the aluminium. It will work harden as aluminium does, but otherwise it will remain *soft*. Whether this is a problem will depend on the application. Probably not much good for an alternator bracket but fine for a cover panel.
Geof
Old 05-13-2011, 01:44 AM
07cob's Avatar
Default All Done
Done and Stoked
Thinking the top (as per photo above) might be a little too high, I adjusted the bows and ended up with the following for a mock up:
So then off to the trimmers and after picking up the car ... I am very happy with the result:
It is amazingly different to drive. I can talk to the passenger without shouting and there is just no breeze. More like a car than a Cobra! Will just have to wait and see how it handles nasty weather.
Geof
Old 05-13-2011, 05:25 AM
Very good Geof! Nice profile and that just might help the rain keep away. Now for the engine?
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 05-13-2011, 06:51 AM
Krait's Avatar
Well done Geof. Looks fantastic.
Geoff
Old 05-16-2011, 04:22 AM
guye's Avatar
Nice job, Geof.
Guy
