November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 05-09-2011, 08:30 AM
Tenrocca's Avatar
Default L76 Straight thermostat housing
As the title says - Im after a straight thermostat housing for a L76 with the stock water pump. Not sure which one to get, as they are all US made and not sure if a L76 over there has the same water pump??
I seem to recall those here who got one used the CSR on the LS1 (Part # CSR 911LS1C) and had to use a different thermostat?
Cheers.
Old 05-09-2011, 01:50 PM
schipps's Avatar
Andrew,
I used the straight housing and got on my mates lathe to take out enough from the inside, for a thermostat to fit into the straight housing.
Mick
Schipps
Old 05-09-2011, 04:13 PM
sambo's Avatar
Shipps, I had my factory water neck modified. The neck is cut at an angle, spun around to face forwards and welded back on. I don't have any photos handy but can take some on the weekend if you like.
Old 05-09-2011, 06:04 PM
Gav's Avatar
Gav Gav is offline
When i fitted the CSR thermostat housing I tossed the standard thermostat and just fitted a standard Holden 308 thermostat. I drilled a 3mm bypass into it and it went straight in. I have had no problems with overheating on 40+ deg days.
Powered by Cu
Old 05-09-2011, 06:45 PM
Aussie Mike's Avatar
Andrew, From memory I machined out Phil N's CSR billet straight housing to take the stock thermostat. It's not a difficult job.
Mike Murphy
Melbourne Australia
Old 05-09-2011, 09:28 PM
LS1 thermostat housings
Old 05-10-2011, 04:28 AM
Outwest34au's Avatar
Cobra Make, Engine: Evans kit, 6 litre, 6 speed, Jag F/R,
I bought a polished alloy 350 chev straight housing and had the back machined out to take the standard L76 thermostat. I also used Devcon to fill the bolt holes then re-drilled them as they are a slighlty different spacing. All works well.
Missed my Cobra budget by thaaaat much.
Ya get that on big jobs.
Old 05-10-2011, 05:10 PM
Kanga's Avatar
Could try this one. THese guys are great.
Billet Thermostat Housing -- Katech Performance Online Store
steve
Old 05-10-2011, 05:55 PM
Cobra Make, Engine: Harrison build #98 with Supercharged 6.2L of Chev Power, TKO600 5 speed gearbox
I needed a straight one also, but knew a guy who does some machining work from his home, so I got him to knock up on for my car. Fitted perfectly and works a treat.
