November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
  #61 (permalink)
Old 07-17-2011, 10:40 PM
Cobra Make, Engine: Classic Revival 3506
Default Vintage wheels on a Classic Revival
Originally Posted by DaveW View Post
Paul,
Have you got a pic of the inside of one of your Vintage Wheels, also, if you have, the distance from the mounting face and the "spokes" (i need some caliper space), and the overall spoke thickness, i'e front to back.
Spoke with Vintage Wheels and Team 3, i need to loose 32mm a side to fit the front wheels and maintain the current wheel to guard distance (3/4" + 1/2" for knock off flange).
VZ hubs, taking out 32mm might be a trick, there's only 16mm between mounting and wheel flange.
Dave with the Jag hubs its quite easy to loose 30 mm from the hub,moving the wheels inboard.
Im not too sure about the Commodore hubs.
The Vintage wheels centers are very think about 62 mm
And the distance from the hub mounting face to the webbing of the wheel is 20 mm.
I hope this is of help
Thanks Paul
  #62 (permalink)
Old 07-17-2011, 11:08 PM
DaveW's Avatar
Cobra Make, Engine: Classic Revival CR3514, LS3, Dual Quads, Holley Dominator EFI, TR6060, VE 3.7 LSD, AP Racing Brakes, 17x8 & 10 Custom Dragway Billet Wheels.
Thanks Paul, great info and great pics,
Dave
  #63 (permalink)
Old 04-05-2015, 02:09 AM
leroy17's Avatar
Anyone care to educate me on lower control arms like this. Are these a custom made item and would that be the common approach for them to be made or are there off the shelf purchase options.
If custom Made, any suggestions on preferred fabricators.
Cheers, and thanks in advance for suggestions.
Is there more to consider by shortening both upper and lower control arms than steering rod end length and potential shock mounting changes, does anything else get altered by just moving the whole assembly inboard by an inch or so ?
How are things like "ackerman" angles or bump steer affected. ?
Upper Control Arm - Front, Chop an inch off the Heim joint end of the arms plate the end, shorten the adjuster lock nuts.
Lower Control Arm - Front, Chop the ball joint end and move an inch towards the bushes, leaving all shock positions as is.
any educated thoughts ?
  #64 (permalink)
Old 04-05-2015, 02:20 AM
beauies's Avatar
Cobra Make, Engine: have brakes, diff, gearbox, steering rack, gear stick, door locks, CR chassis 3518
Ian, at Classic revival in Hornsby NSW supplies them to his kits
Rate This Thread:
