Like Tree5Likes
Old 01-29-2012, 06:29 PM
Cobra Make, Engine: Classic Revival
Default Classic Revival Roll Bar
Hi guys & girls,
Need some help tracking down an earlier version of CR roll bar, recently ordered one from Ian at Classic to find the new one is narrower and does not have a long leg to suit the chassis tube. Ian told me the supplier does not have the older tooling. Just wondering if anyone has a surplus older style still kicking around the shed, the original was approx 163mm centreline bend rad or leg to leg centre 326 - 327mm. Checked with Uneek bending and i would need to supply SS Pipe and min setup price $300 plust program fee $25 and thats if they can produce the the rad expensive exercise for a one off. If others were in need of the older style i would be happy to here from you as it would be more benificial to get a few made if this is the only option.
Appreciate any help on this.
nigel
Old 01-29-2012, 07:22 PM
Nigel,
Everyone I know has had the roll bar made up differently to suit their taste.
it would be worth getting a message to Aussie Mike if you are down South.
Ben
Old 01-29-2012, 07:35 PM
Tenrocca's Avatar
Nigel - I relocated the mount on the belt mount bracket to suit the bar I got (from Snakebite at the time - but I dont think they make them anymore?) The narrower the bar the more centered it looks as the outboard mount is too far inboard. I think mine was 300mm.
Old 01-29-2012, 08:00 PM
cheers guys, holes already located in body to suit receiver tubes so need to match, have drivers roll bar in place was trying to fit passenger bar, at this piont have polished caps and escuchions in place just in case i find the right fit. Have to make decision on filling holes as due to go for paint this winter.
Old 01-29-2012, 09:51 PM
leroy17's Avatar
I have used both of these businesses and were very pleased with their work, not for roll bars but for other things. I know that they are located on the Gold Coast however a quick call will answer if they can bend to the size you are after without set up costs. Both also should be able to supply and polish tube as well.
V=http://www.protube.net.au/
Pipe Bending Services,Handrails & Balustrades Services, Metal Rolling Brisbane, Gold Coast - Tube Bend
Old 01-29-2012, 11:26 PM
thanks leroy17 will contact both to see what they can do for me
cheers,
nigel
Old 01-29-2012, 11:44 PM
Aussie Mike's Avatar
I only have dies for 1.5" in 6.5" CLR. That's 13" (330mm) center to center on the hoop. The originals were 1.5" diameter tube but it looks a bit thin to some and they prefer 1 5/8 or 2". I've been looking at getting 2" dies.
Mike Murphy
Melbourne Australia
Old 01-30-2012, 03:01 AM
Modena's Avatar
I bought roll bars from CR for my round-tube.
They cost $470 each, including the sleeved third-leg and hefty mounting plate which the third-leg welds to - these are fully functional roll bars. The mounting plate is then bolted to the chassis. This price was in mild steel.
They pipe diameter is 50mm, they are 310mm centre to centre
$470 each, mild steel, and deformed by bending.
Your quoted price in stainless sounds cheap to me.
Ben in AU
Old 01-30-2012, 03:51 AM
RODA's Avatar
Cobra Make, Engine: Classic Revival LS1 6spd
Nigel,
I purchased stainless steel tube from Fragesters in Moorabbin and had then rolled at A Bending in Dandenong. Their set up fee was about 150.00 for memory. My car is in bits at the moment being painted so you are more than welcome to borrow one for a template. You will also have to fabricate base brackets to fix the third leg through the body to the chassis, which are also floating around in the box of bits that us to be my car.
Rod
Old 01-30-2012, 05:13 AM
I bought a pair of single hoops from a Mob in Riverstone, Sydney that build proper race roll bars and cages out of Chrome molybdenum steel tube. They are light and unbelievably strong. These are CAMS legal and incredibly light. The tube is 2" OD with a wall thickness of about 1/16" . No deformation (that would negate CAMS legality) and they cost about $250 each. they are black steel finish so need to be painted or maybe ceramic coated. I think chrome might interfere with the metal properties. The third leg is also Chrome Moly and it simply bolts to the frame by a thick plate welded into the base of the tube. If your mild steel bar is correct it must be at least 1/4" thick and be made out of hot drawn seamless steel tube or at least cold rolled and welded steel tube. The latter must be of a thicker wall.
Old 01-30-2012, 03:31 PM
Modena, i bought the original bar from Ian at CR that was back in 2007 and without thinking i ordered another just before christmas to find it was totally different, even Ian was surprised when i sent it back, the only thing common was the material 40NB 316 stainless its approx 49-50mm od with 3mm wall the quality was no where near as good as the one i have and at $390 i thought that i could invest in local manufacture.
Mike, my current bar is not quite 2" but would work in 2" dies i think the big issue is the die Rad that Ian had his supplier use was 6 7/16" CLR not your every day run of the mill unless you want to make your product exclusive, Ian's current bar CLR is 155mm. Let me know if you get new 2" dies. With your experience is it viable to get 330mm CL to CL cut and rejoin to reduce leg centres 4 mm and refinish/polish???? If i hadn't prepared the body holes based on drivers bar i could have got away with 330 centres, not noticeable!!!! If all else fails i'll fill inner body hole LHS and go with standard die bend available through various outlets.
Rod, i can get the 316 SS 40NB pipe ok will go and talk to A Bending to see what they can do, thaks for the offer to borrow, i do have the drivers side fitted and can use that as template.
Rob thanks for input, already have polished 316 SS drivers hoop 3mm wall can match material biggest prob is bending die with correct CLR with no deformation.
Thanks again guys for the input.
nigel
Old 01-30-2012, 03:39 PM
nigel
Old 01-31-2012, 03:44 AM
Modena's Avatar
i said "mild steel" but i really dont know what type of steel they are, just not stainless!
wall thickness is 4mm
Ben in AU
Old 01-31-2012, 01:42 PM
I must admit what Ian at CR sent me was raw SS try the magnet test it could be a 400 series grade SS that will attract a magnet as mild steel does, if magnet does't attract then its likely to be 304 or 316 grade in raw state takes a bit of polishing. Your comments and picture highlights the quality issues i had and sent it back, Ian said supplier could not see a problem, supplier obviously does own a classic vehicle.
Old 01-31-2012, 09:01 PM
Mando's Avatar
"couldn't see a problem" gee what a a surprise!!
Regards.
Mando
Old 02-01-2012, 02:47 AM
boxhead's Avatar
Bite your tongue David, Bite your tongue.
Cruising in 5th
Old 02-01-2012, 04:55 AM
Modena's Avatar
where's the fun in that
Ben in AU
Old 02-09-2012, 02:45 AM
Hi All,
Just to let you know I''m in the US at the moment and dropped a pile of cash on a 2" die for my tube bender and also got all the parts to convert it to hydraulic operation. All going well I should be able to produce some acceptable looking roll hoops in stainless steel and chrome molly for very competitive prices.
The hoops will be on 330mm centers or 13" which should suit many Cobras out there.
I bought the parts mainly because I wanted to redo the hoops for my car but it would be nice to off set some of the significant outlay in tooling. There will be some work to get them looking OK but I will keep you posted on my progress.
Mike Murphy
Melbourne Australia
Old 02-09-2012, 07:35 AM
Jerry Clayton's Avatar
What part of the US are you in---If anywhere in the middle I would sure make your aquaintance
Jerry
Old 02-10-2012, 09:17 PM
Hi Jerry,
You are a bloke I'd definitely be keen to catch up with for a few beers and a chat. What part are you in?
Our company HQ is in Huntsville Alabama and I get over there a couple of times a year. The last few trips I've been braking the journey by stopping a night in LA, Dallas or Nashville on the way in and out. It's a long flight so it gives me a chance to adjust and have a look around.
A few years back my trip lined up with DVSF in Ohio and I took a side trip to check it out. I'd be keen to do another side trip to check out a big race meet or a swap meet.
I just got back home today but I'll have to try and do something on the next trip.
Mike Murphy
Melbourne Australia
