02-02-2012, 01:20 PM
NSW
Upgrading rear tyres and wheels
At the moment, I have two 315x35x17" Sumitomos on 10 1/2" x 17" Vintage Pin Drive rims which have only done 2,500 k's fitted to the rear of my Cobra. I am considering changing the look of my car to get a more beefy appearance in the rear wheel department by fitting 295x50Rx15" B.F. Goodrich Radial T/A 's tyres to new 10 1/2" x 15" Vintage Pin Drives.
I am seeking expressions of interest from anyone who might be interested in purchasing the two 315's on 17" Vintage Knock Offs for $1,000. That price is for the rim and tyre only and does not include the Adapters or Spinner Kit.
Regards
Baz
02-02-2012, 01:55 PM
SA
That's a good way to go Baz. IMO, the 15" wheels will look great....very period correct, and as you say, "beefy". Worth doing.
Glen
02-02-2012, 01:57 PM
Vic
Baz what is the offset, the stud pattern, and the centre hole diameter?
Ben in AU
02-02-2012, 02:32 PM
NSW
What about the fronts Baz?
02-02-2012, 03:54 PM
Baz have you considered these instead of the BFGs?
Mickey Thompson Performance Tires & Wheels
Don.
02-02-2012, 04:11 PM
02-02-2012, 05:42 PM
NT
There is only 1 choice.
Has to be BillBoards.
Cruising in 5th
02-02-2012, 05:58 PM
NSW
Hi Andrew,
I am leaving the 17's and the Sumo's on the front. I'm quite haoppy with the appearance in that area and also their grip isn't too bad either.
Baz
02-02-2012, 06:18 PM
VIC
Are you going for 15's for drag racing? Those TA's may not be the best choice. Maybe look at some drag radials. BF Goodrich make some with tread.
Mike Murphy
Melbourne Australia
02-02-2012, 06:24 PM
Baz, will your brake and callipers fit into the reduced space of the 15" wheel?
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
02-02-2012, 06:39 PM
NSW
Hi Modena,
Thanks for your interest. I have changed my mind after some advice on a PM. I have been recommended a set of Goodyear 285x40x17 GS-D3's for the rears which have a much higher wall height and just what I am looking for. This way, I don't have to buy a new set of 15" rims and end up with the look that I am after.
Thanks everyone for their interest.
Baz
02-02-2012, 06:41 PM
NSW
Cobra Make, Engine: Homebush. Lexus quad cam V8, R154 Supra box. Oh what a feeling.
Hey Baz
Any new pics of your car? Haven't seen any since you finished it.
 !!Its good to be stroked but i'd rather be blown!!
Proud member of the Bclub Central Coast chapter
02-02-2012, 07:08 PM
Originally Posted by Baz
Hi Modena,
Baz
Hey Baz...
You might want to re-check that ....
I'm pretty sure that the "Wall Height" on the Sumitomos will work out to be 110.25 mm , and the GS-D3 Goodyears to be 114 mm....
That's only a "flea's doodle" difference !
Aren't the "Middle numbers" ......e.g. 315/ 35/17...and 285/ 40/17... on all of the tyres sizes a "percentage" of the width ?
i.e. 315 X 35% = 110.25mm
285 X 40% = 114.00mm
Difference in "Wall Height" = 3.75mm ( 15/100ths of an inch )
Have I got this wrong ??
Warren.
02-02-2012, 07:26 PM
NT
You have it 100% correct Wazza (as if you doubted yourself)
Cruising in 5th
02-02-2012, 08:07 PM
Yep. I have the 285 40s in Sumitomo.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
02-02-2012, 08:31 PM
VIC
Are you still running round eith rego height suspension? Dropping it a couple of inches front and bsck will make the tyres fill the guards much better. Probably make it handle better too. Mine was pretty horrible with the suspension wound up both in looks and ride.
Just make sure your tyres clear the edges of the guards. From my memory of your build pics your wheel offsets put the tyres out near the lip. You wouldnt want one to rub and stuff up your nice paint. Thats one of the reasons i didnt paint mine before driving it. Ive found a few spots where the tyres rub and fixed them now.
Mike Murphy
Melbourne Australia
02-02-2012, 08:40 PM
NSW
Thanks Mike. Everything fits just right now.
Baz
02-02-2012, 08:45 PM
NSW
Originally Posted by Wazza
Hey Baz...
Aren't the "Middle numbers" ......e.g. 315/35/17...and 285/40/17... on all of the tyres sizes a "percentage" of the width ?
Warren.
Thats right Warren, but the Goodyears are half an inch larger in the overall diameter which is what I'm after.
Baz
02-02-2012, 08:52 PM
VIC
1/2" is going to be hard to pick as it's only 1/4" top and bottom. I think they will just appear to look bigger because they have a taller sidewall. The gap to the guards will be about the same.
Mike Murphy
Melbourne Australia
02-02-2012, 09:08 PM
vic
The larger tyres will throw your speedo out Baz, along with the tune for your shift points in the auto.
Just a thought.
Powered by Cu
