November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 02-09-2012, 11:05 PM
boxhead's Avatar
I am sure you can, what it will end up costing is a big ?
Yes you will require immobiliser (Kits are available)RhinoCo Technology :: Alarms and Immobilisers
You will need to meet emissions as per engineers requirement, which I think in WA will mean 96 engine ok with cats (ask engineer)
Ride height is 100mm minimum.
You may be required to supply torsion and beaming specs, as I would think the other DAX vehicles have most likely have been assembeld and registered in UK and imported as complete vehicles.
Maybe ask around here if other DAX owners have a copy of testing paperwork, Engineer again will advise what you need.
Cruising in 5th
Rate This Thread:
