1Likes
03-05-2012, 08:11 PM
Another Tow vehicle in the build...
Not really sure if anyone interested or not but i'm gunna post some progress pics anyways....
Decide I needed a tow vehicle ( I tow a car trailer for work a couple of times a week about 200k round trip each time) that had a greater towing capacity than 2100kg (my VE SS sportwagon) and had more grunt than our 3 litre turbo diesel Rodeo.
What about a Rodeo, 3 tonne towing capacity, with a V8?? Can't buy it so why not build it.
So...... I have started....
Bought a written off 09 VE SS manual ute for $6k at auctions just before Xmas.
The donor vehicle complete with L98 6.0 litre and Tremec TR6060 6 speed manual
I then managed to get a 2007 Rodeo turbo diesel 4x4 that was missing on one cylinder for $12,500. Replaced a dodgy injector and good as new. Now to sell the turbo diesel engine...
Engine has now been taken out of the SS and the sell off of surplus SS parts has begun..
If ur interested i'll keep posting as it happens.... I may have a buyer for the motor & box out of the Rodeo... $4500....... fair price i think....
03-05-2012, 08:20 PM
vic
Cool, when you are finished you can fit a duramax to my Pajero!!
Powered by Cu
03-05-2012, 08:49 PM
NT
Will be an interesting project, do you need to do anything to chassis to increase towing capacity?
Cruising in 5th
03-06-2012, 12:20 AM
Boxy the 3.0 litre intercooled Turbo Diesel (after Jan 2007) in 4X4 mode came standard from the factory with a 3000kg braked towing capacity. All others models were either 2500kg or 2000kg. Spoke to my engineer and he said the towing specs it leaves the factory with is what it keeps.... So if i put the L98 in it retains the same towing capacity.
03-06-2012, 12:31 AM
03-06-2012, 03:29 AM
Q
I'm not sure why, but anything with a V8 conversion is instantly a cool thing. I think I'd even buy a Volvo 240 DL Wagon if someone had put a high winding small block in it...
I'm keen to see how the conversion goes. I might sit back and wait to hear your thoughts about the ECU/wiring/sensors before I do anything.
Craig
03-06-2012, 02:46 PM
NSW
Cool project!
Keep us updated.
Ben
03-07-2012, 02:28 AM
AUS
Ash, nice to see some photos of the project. Keep the updates coming...
03-07-2012, 05:28 PM
Not much happening at the moment. Trying to work out how to integrate the V8 fuel pump with the Diesel lift pump and trying to keep it all in the 120 litre long range tank..... It can be done.... apparently, just gotta build a surge tank inside the big tank to mount the V8 fuel pump assembly.
Mean while I have been slowly removing all the 'good bits' for later sale on flea bay....
03-07-2012, 06:21 PM
ACT
The only 'good' bit I see in that photo is the Kubota? tractor
SLIPRY
03-07-2012, 06:25 PM
ACT
Craig, in the 80's I very nearly bought a '69 Volvo 142 with a 302 for the hell of it. Conversion was a bit dodgy though.
SLIPRY
03-08-2012, 04:38 AM
NSW
Cobra Make, Engine: 1995 Snake Pit DRB "Coca Cola" , 5.0 LT HO , T5
Sounds like a pretty cool project but what about the Rodeos diff? will you need to change the ratio? surely it wouldnt be compatible with the higher revving V8 will it?? Id imagine 1st and 2nd gear would be almost useless and wouldnt you be revving way too high at highway speeds?
03-08-2012, 04:59 AM
Q
With the TR6060 and its nice tall overdrive, that will work very well with the 4.3:1 (if standard) rear ratio.
First gear will then make it nice and easy on the clutch to not have to slip it much while crawling along in traffic or through the pits.
Craig
03-08-2012, 05:09 AM
NSW
Wow, well if thats the case it sounds like its going to be an awesome project  Cant wait to see the updates....
03-08-2012, 03:57 PM
That's right Craig, I did quite a bit of research on gearing before I decided to start. The Rodeo has quite a few different reatios depending on engine and drive ie 4x2 or 4x4. Diesel 4x4 ratio (4.3) makes it about 1750rpm @ 100 which is pretty good. It is a TR6060 tremec so the ratios are a bit different to the T56, really good down low in first gear and .57 in 6th.
03-08-2012, 04:40 PM
Qld
Prick of a job getting dash and other accessories to work
U might have to pay someone to sit and work it out
Gets expensive hehehehehehe
03-08-2012, 08:50 PM
Cheers Jim,
Yes I know..... Already been emailing some carnival clown..... apparently he's gunna have a look at it for me.... lives on the Gold Coast too....
03-08-2012, 10:16 PM
I think its a great project....as a tow vehicle the L98 is going to have plenty of grunt..all the best with keeping the fuel up to it.. I have a ve caprice it had a tow bar on it when I bought it. I was stuck one day and had to use it to tow an enclosed trailer no trouble for it to use 25lt/100k's when it normally runs along at around 9-10... the 3.0l diesel hilux I have however pulls the same trailer and uses around 14 - 15 lt/100k
Cheers all the best with the build
03-08-2012, 11:30 PM
I currently tow an enclosed trailer with a VE sports wagon SS & it averaged 17.5 l/100 last trip to the nationals. Its not really the fuel economy but a relatively inexpensive tow vehicle that can tow 3 ton & has plenty of grunt. The diesel just doesn't have the power when u put the weight on the back.
03-09-2012, 01:04 AM
Qld
yes they all think im a carnie at day care when i drop off kids cause they see my work
shirt and see sideshow and think im from the circus heheh
