Like Tree7Likes
  #41 (permalink)
Old 11-05-2012, 02:44 AM
Philm's Avatar
Default More than you need.
The 363 is a larger bore as you have mentioned, of 4 1/8th bore compared to the standard 4 inch bore.
I think you just have to see what you want to do with the car, a 5ltr windsor with some heads nice cam will be plenty enough to get you into trouble on the street.
A 347 stroker is a nice option to give yourself a bit of a fright every now and then, just don't rev it, if you keep it under 6k it will last for ever.
I have an Iron eagle block with a 363 capacity and love it, revs to 7500 and has more power than I will ever need.
Another thing you should concider is the handling and braking of the car, they so unforgiving and to had a couple hundred more HP is not a good mix. I would also look at a brake upgrade and a bit of a going over the suspension as well.
Phil
  #42 (permalink)
Old 11-07-2012, 02:05 AM
ICETOO's Avatar
Cobra Make, Engine: DRB #145, Ford 5.0 HO
Thanks Philm.
I appreciate the guidance.
This is a must do and will do the brake upgrade (including booster/servo, calipers, rotors, lines, bias, master cylinder, etc) when the engines out.
I am networking with a few suspension mobs ATM for the best options to suit the configuration, as I want it to be drivable in traffic as well as the open (without a need for a defibrillator)...thanks again Adam.
  #43 (permalink)
Old 11-07-2012, 03:50 PM
Aussie Mike's Avatar
Make sure you talk to some folks experienced in setting up a DRB. There's plenty that have made them handle and stop real well. A regular suspension shop may look at the torana components and think the ususal setup for torana will work. The weight and weight bias of a Cobra is totally different so that setup may not work.
Mike Murphy
Melbourne Australia
  #44 (permalink)
Old 11-08-2012, 12:50 AM
ICETOO's Avatar
Thanks Mike...when I get back from this trip, so start of DEC will PM Ash (Towmaster) as he clearly has it sorted well and proper.
Just a short one as can not take too much of the ships bandwidth.
Cheers Adam!
