February 2026
Like Tree8Likes
  #41 (permalink)
Old 06-21-2013, 11:55 PM
You need to phase the tailshaft correctly. you want angle. You have to make sure both flanges are parallel within .5 degrees. If the tailshaft is dead straight it won't allow the needle roller to move creating a flat spot.
JD
  #42 (permalink)
Old 06-22-2013, 12:20 AM
Zedn's Avatar
It wouldnt be possible to have it straight with a jag diff unless you put the motor to one side of the car. The jag pinion is offset from centre.
  #43 (permalink)
Old 06-26-2013, 07:01 AM
martrogers's Avatar
Cobra Make, Engine: Homebush fibreglass
Liam
Great car, great video. Would like to pop over for a drool some time.
If in doubt mumble.
  #44 (permalink)
Old 06-26-2013, 02:53 PM
Zedn's Avatar
G'day Martin,
It's been a long time, car looks very different from when you were last here.
Your welcome anytime.
Liam
  #45 (permalink)
Old 06-30-2013, 04:10 AM
Zedn's Avatar
Headers finally finished. I ended up getting the face of the flange machined to make sure it was perfectly flat. They are now in being ceramic coated. Im pretty happy how they turned out. Not the ideal design for flow, but all i could make fit.
  #46 (permalink)
Old 06-30-2013, 04:31 AM
Modena's Avatar
very nice Zedn, I'd be proud of that.
Ben in AU
  #47 (permalink)
Old 06-30-2013, 04:42 AM
Mando's Avatar
They look great, be sure to show us how they turn out after you get them back from being ceramic coated. Are you getting black or white?
Regards.
Mando
  #48 (permalink)
Old 06-30-2013, 04:50 AM
Zedn's Avatar
Polished silver finish.
  #49 (permalink)
Old 07-02-2013, 09:24 PM
Zedn's Avatar
Back from competition coatings. They look amazing.
guye, Mando, sambo and 2 others like this.
  #50 (permalink)
Old 07-02-2013, 09:31 PM
d488y2's Avatar
Cobra Make, Engine: Cobra Replica, 5.0 Supercharged Coyote
They look Awesome !
Great Job.
  #51 (permalink)
Old 07-02-2013, 09:47 PM
Aussie Mike's Avatar
Great work! You would have to be proud of that finished product.
Mike Murphy
Melbourne Australia
  #52 (permalink)
Old 07-02-2013, 10:52 PM
Zedn's Avatar
Yep, im stoked.
They did a really good job, coated inside and out. Only small problem is there were a couple of small areas where i had a blade break on the saw and leave scratches on the pipe. I regret not sanding these out as you can see them through the finish. Not a big deal though as they will be difficult to see when on the car.
  #53 (permalink)
Old 07-03-2013, 06:15 AM
guye's Avatar
Great job Zedn!
When I see you guys doing stuff like this I get a bit scared of starting my kit....
Then I suppose I could always ask for your help :-)
Guy
  #54 (permalink)
Old 07-03-2013, 07:27 AM
jcraigau's Avatar
Liam, they look spectacular. Great job creating all of those bends!
Can't wait for the shots once they are in place.
--JC
  #55 (permalink)
Old 07-05-2013, 02:09 AM
AC-460's Avatar
Best way to keep those flanges straight when your welding them up is to find yourself an old head and bolt them up tight and weld them on when there rock solid... Ive seen people do this before its very hard to keep them straight unless you let them cool with them bolted up tight
Originally Posted by Zedn View Post
Got some more work done on the headers.
This is the drivers side. Very tight, and then throw in the steering shaft just to make it tricky!
Had to do a lot of pie cuts to get the tight bends.
  #56 (permalink)
Old 07-05-2013, 03:20 AM
Zedn's Avatar
I clamped them to a piece is 50x50x5 angle and a saw stand. The Flanges were not flat to begin with. I also fused around the ends of the pipe (head side) as due to the tight bends the pipes were not completely square on the end and I didn't wanted a smooth transition into the pipe.
I just had a local muffler shop skim a bit off to make sure they were flat. Wish I had a mill!
  #57 (permalink)
Old 12-24-2013, 12:35 AM
Zedn's Avatar
It's alive!
LS3 First start. - YouTube
  #58 (permalink)
Old 12-24-2013, 12:58 AM
Good job. Its always great to fire up a new project fire up. Now you've something to do on 31st of December............'bout Midnight !
Rog 246
Harrison #100
  #59 (permalink)
Old 12-24-2013, 02:49 AM
750hp's Avatar
Well done. I just had another look at your walk around video. Some great detailing throughout!
Craig
  #60 (permalink)
Old 12-24-2013, 04:09 AM
Cobra Make, Engine: Pace 427SC. LSA Supercharged with 6sp TR-6060 trans.
Congrats Liam! Great to see her running and she looks and sounds awesome!
