Like Tree197Likes
  #161 (permalink)
Old 11-12-2015, 06:36 PM
boxhead's Avatar
Harsh coming from a man who I watched hit some tyres in a hill climb a few years ago.
Originally Posted by Gav View Post
You should have fitted dodgem car bumpers to yours too Ben.
DaveW likes this.
Cruising in 5th
  #162 (permalink)
Old 11-12-2015, 07:00 PM
Gav's Avatar
Gav Gav is offline
that smear of white paint on the front of my car is called 'patina'.
People pay big money to replicate it
deano59, boxhead and DaveW like this.
Powered by Cu
  #163 (permalink)
Old 11-12-2015, 09:08 PM
That's not nice Boxhead.
Unless you have proof!
Sorry to hijack the thread!
Aussie Mike, boxhead, Gav and 3 others like this.
  #164 (permalink)
Old 11-13-2015, 01:53 AM
Nice work. Just one observation is that round tube on those skinny pads of your hoist. I have a square tube chassis with extra wide pads, the other day I was loading up the front suspension with jacks and poles. The car car moved side ways half an inch and scared the crap out of me. Just looking at yours looked a bit scary. Can you weld up some special pads with a y fork to stop it sliding. Even if you put a bit of force with a power bar on a bolt could shift it. I love your hoist without the base plate. I have a old style Molnar.
JD
  #165 (permalink)
Old 09-15-2016, 04:54 PM
DaveW's Avatar
"Not the first Start"
First start a few weeks back, engine was revving pretty hard at idle, the IAC ports on the base of the quads were over hanging the manifold mount in free air, The IAC wasnt functioning correctly, and a lot of air via the oil catch can . PCV circuit.
With the IAC ports, I hadnt installed the blanking plate supplied by Holley with the quads, didnt even notice they were supplied in the box, but i had made my own incorporating a throttle cable mount....now going cheap !
Bottom of the throttle body showing the IAC port and my flange plate.
Correct plate on the manifold with the blanking tab
Next was the PCV circuit and catch can.
A bit of googling revealed i was drawing too much air through the PCV circuit, so pulled the original inlet manifold from storage and measured the PCV port on the manifold.
The tube internal diameter is just 2.5mm and my hose from PCV vent to oil catch can then to throttlebody was -4an, so 6.35mm
Made a small restrictor to fit into the -an port fitting with a 2.5mm hole in it.
back together and ready for start #2
With the IAC function i have found that Holley use a Chrysler type IAC motor, but the loom i have is pinned for a GM type, same Delphi Metri-pack 150.2 4 way connector but the stepper lo circuits a reversed wiring...why why why.
Here is a low res video of "Not the first start"
I had the IAC port blocked in this start up hence the need to adjust the throttle plates
[ame]https://www.youtube.com/watch?v=LIUtUgGmQls&feature=youtu.be[/ame]
cheers to all and have a great run at the Nats.
Dave
  #166 (permalink)
Old 09-15-2016, 06:59 PM
gjkrv8's Avatar
sounds awesome Dave, did you sneak a lumpy cam in there too? cheers Gregg
boxhead likes this.
  #167 (permalink)
Old 09-15-2016, 11:11 PM
boxhead's Avatar
Sounds damn fine for full exhaust.
Well done, I can see the grin from here.
Cruising in 5th
  #168 (permalink)
Old 09-16-2016, 06:50 AM
Default Miss fire
ooops
Bill
